Wheel Fitment Guide
A 215 and 245 will work fine. I would still say there you may need to roll the fronts when you lower it. You'll have to watch for any signs of rubbing and I saw watch because it is hard to hear the fronts rubbing.
Hey guys, just looking for some insight on fitment. I plan on getting some Te37SL 18x9.5 +45 squared. Do you think I'll have any issues running 225/40 on the fronts and 255/35 on the rears? I'm currently on coils and have my fenders pulled and rolled with the bumper tab relocated. Thanks!
Originally Posted by s2000Junky' timestamp='1464248128' post='23976785
[quote name='Rrkr' timestamp='1464243003' post='23976772']
[/quote]
The 9 +45 will stick out 7mm less then the 9.5, which would be a better looking/performing fit for the front, but id still run the 245, its the perfect pairing with just the right amount of stretch. 225/40 on a 9" is ok, but its a better mate on a 17" where there is more sidewall and generally a slightly wider section width vs the 18" counterpart.
Originally Posted by Rrkr' timestamp='1464323901' post='23977704
[quote name='s2000Junky' timestamp='1464248128' post='23976785']
[/quote]
[/quote]
So I should run 18x9+45 with 245/35 for the fronts and 18x9.5+40 255/35 for the rears? Thanks for all your help again, just making sure I don't get wrong sizes!
Originally Posted by s2000Junky' timestamp='1464325262' post='23977710
[quote name='Rrkr' timestamp='1464323901' post='23977704']
[/quote]
[/quote]
[/quote]
Yes for the front, no for the rear. You want your original 9.5 +45 for the rear, not +40.
