Wheel Fitment Guide
Old Jul 2, 2007 | 09:44 PM
  #171
beesting's Avatar
Originally Posted by spa-zz,Jul 2 2007, 02:32 AM
A 205 to 245 stagger will be perfectly fine. In fact that's the stagger that Honda uses if you look closely. On the AP1 the rears measure out at a 245 width despite the 225 labeling. On the AP2 the fronts run narrow like a 205 even though they are labeled as a 215.
Ubetit says he had some rubbing issues and +42 is indeed aggressive. But like he said, some will tell you it fits. Not every S2000 with rub the same way. You could try some Toyo T1 tires; people say they run a little bit narrow. Or, you could add a smidge of negative camber up front if you rub.
If you plan to lower the car 2" or something, then you might try to find some wheels with higher offsets.
Cheers,
Ken
thanks Ken
it seems as though the only tire set i can get from tirerack with
front: 205/40/18
rear: 245/35/18
is michelin pilot sport ps2.
http://www.tirerack.com/tires/CompareTireR...er=&RunFlat=All
does this tire have the required load rating?
i live in australia and the michelin website does not list these tires here
is it possible to use different brands of tires for front and back wheels? or, same brand tires but with different treads? what are the disadvantages in doing this?
thanks mate.
Old Jul 2, 2007 | 11:17 PM
  #172
beesting's Avatar
found some available in australia:
YOKOHAMA S DRIVE 205/40/18 and 245/35/18.
they are reasonably cheap. has anyone used them before?
Old Jul 3, 2007 | 04:35 AM
  #173
spa-zz's Avatar
I would just give Tirerack a call and they will help you out with tires and load ratings and such. I wouldn't mix brands front to rear.
Old Jul 7, 2007 | 09:37 AM
  #174
JP Money's Avatar
Mr. Spa-
Been reading and researching and researching some more, but I am going to bite the bullet on some rims and the specs are as follows:
Front:
18x7.5" with a +48 offset
Rear:
18x9" with a +48 offset
as per the chart, I should run a 215/40 and a 245/35. I would have 3mm more clearance than the charts says for the rear and be perfect up front. However that really limits my tire choices. If I wanted to run a 255 width in the rear, I could get the Pzero Nero M+S that I really like. Is that too much stagger though? I would think 215 and 255 to be too much of a difference. I know stock is 205 and 245 so its basically the same thing, but I just want to clarify that. If it is too much, how about 225 and 255, I know I would be a whole 7mm over in the front, so would I just be able to add camber that would balance that out, or would I have to get the fenders rolled to balance it out? I know there is alot to take in, but I am always picky and want to make sure its going to run good before I do anything. (I had a MINI that was easier to work with, it had a 4x100 bolt pattern and a +35 to +45 offset threshold).
Old Jul 7, 2007 | 10:45 AM
  #175
spa-zz's Avatar
JP...
The 215f and 255r will be perfect IMO; I would do that. I don't think going to 225 front would be worth it. The S2000 doesn't lack for turn-in ability and is already loose enough. Still if you do decide to run the 225 in front you could do what you said and experiment with fender rolling and/or additional negative camber. However if you go with wider tires in front and more camber, the front end might have more bite than you want...
Cheers,
Ken
Old Jul 7, 2007 | 12:51 PM
  #176
GODZUKI's Avatar
Hi all,
I have chosen the following setup for my s2k, but
I was wandering if I would have clearance problems
if I had 6 pot or 4 pot calipers on.
I hope the above answer will not be a case of
trial and error...
For the front:
7.5
Old Jul 7, 2007 | 10:28 PM
  #177
JP Money's Avatar
Mr Ken
Thanks for confirming what I thought about the 215/255 vs 225/255 sizes. You are a great asset to these forums. <that one is for you.
Old Jul 8, 2007 | 05:38 AM
  #178
spa-zz's Avatar
Godzuki, I can't comment on caliper clearance questions. Sorry.
JP, Thanks.
Old Aug 3, 2007 | 02:15 PM
  #179
Silver S2k4's Avatar
question.....
I have really wanted to get some 19" wheels on the S but can't find anything that will fit and not super expensive.
I found a set, heres the specs:
Front 19x8.5 45mm offset
Back 19x9.5 55mm offset
My car is slammed so my question is, how much are they going to rub? Will it be drivable at all or will I damage too many things if I put these wheels on?
Thanks.
Old Aug 3, 2007 | 02:39 PM
  #180
spa-zz's Avatar
It depends on what width tires you choose. Unfortunately I don't have data for cars that are "slammed." Hopefully another member can chime in here and help.
