Wheel Fitment Guide
Another fitment question...
I have 17 X 9 +45s.
So I see from the wheel fitment guide that a 245 tire will fit on a wheel with +45 offset on stock suspension without rubbing (the rear). It is the widest tire for that offset that will fit without rubbing. My question is, if I am running a 255 tire but with UK suspension at -2 degrees of camber in the rear, will I need to roll? I have heard that quote passed around which says "for every degree of camber, you get 10mm more additional clearance" or something like that. I would prefer to not do the rears if possible. Thanks again.
I have 17 X 9 +45s.
Originally Posted by spa-zz,Dec 6 2005, 07:58 AM
For the front:
Offsets lower than +43 are not recommended on the front because a very narrow tire would need to be used to avoid rubbing.
+43 to +47 offset: 205 tires, 6.5" - 7.5" wide wheel
+48 to +52 offset: 215 tires, 7.0" - 8.0" wide wheel
+53 to +57 offset: 225 tires, 7.0" - 8.0" wide wheel
+58 to +62 offset: 235 tires, 7.5" - 8.5" wide wheel
+63 or higher offset: 245 tires, 7.5" - 8.5" wide wheel
For the rear:
Offsets below 40 are not recommended for the rear because a tire narrower than the stock tire would need to be used to avoid rubbing.
+40 to +44 offset: 235 tires, 7.5" - 8.5" wide wheel
+45 to +49 offset: 245 tires, 7.5" - 9.0" wide wheel
+50 to +54 offset: 255 tires, 8.0" - 9.5" wide wheel
+55 to +59 offset: 265 tires, 8.5" - 9.5" wide wheel
+60 to +64 offset: 275 tires, 9.0" - 10.0" wide wheel
+65 or higher offset: 285 tires, 9.0" - 10.0" wide wheel
For the rear:
I second sukii's question about the rear. I've noticed the same on my stock ap2 rear with stock 245/40/17 re050. I'm interested in seeing if I can use a 17x8.5 +45mm with 245/40/17 tire in the rear now and later when I lower the car. From my observation of the car at its current state, it would seem impossible for the rear to clear the additional 20mm without a) fender roll and/or b) more neg. camber.
Could some one with actual experience with 17x8.5 +45mm rear with 245 tire chime in? Thanks in advance.
Originally Posted by spa-zz,May 2 2010, 01:44 PM
You guys are forgetting that negative camber increases with suspension travel. :-) So, that clearance you are measuring doesn't mean a whole lot.
Ken
Ken
Originally Posted by sukii,May 3 2010, 11:42 AM
True that negative camber will provide additional clearance but it would not be beneficial at stock height.
I'm just worried that if I decrease the offset at all in the rear, the tires will potentially damage the fender lip. I would really like to stay away from modifying the fender as well.
Trust me, the chart is accurate. It's not a guess, it's data compiled from actual users. In fact, it's on the conservative side. People have gotten away with lower offsets than shown here.
<Disclaimer>
Unless something is wrong with your car in particular...
</Disclaimer>
Hey guys,
Yet another offset question.
Here are the wheels:
17x8.5 front +47
17x9 rears +47
I'm 90% sure they will fit.
1. Will they fit on stock suspension, including stock height?
2. Will the rear sit flush or poke?
3. I'm happy to run a 215/40/17 tyre on the front end, but will this more likely rub on the suspension or the front fender? And can i avoid this by rolling the front?
Cheers.
17x8.5 front +47
17x9 rears +47
Cheers.
Originally Posted by spa-zz,May 26 2010, 11:14 AM
The front will be close but should be ok.
You didn't say what rear tire you plan to use so we can't say how the fit will be.
Cheers,
Ken
Cheers,
Ken
How much camber would be required for flush fitment?
Cheers.
