Wheel Fitment Guide
Old Sep 1, 2013 | 08:15 PM
  #761
v10killer's Avatar
Alright guys a quick question...lowered a inch and a half wanting to run 18x9 +35 in the rear....what tire size could I do this with and is it possible with a roll on oem quarters?
  #762
v10killer's Avatar
Old Sep 1, 2013 | 09:52 PM
  #763
s2000Junky's Avatar
Could you repeat that, I missed the first one
Old Sep 1, 2013 | 11:05 PM
  #764
v10killer's Avatar
My bad terrible internet connection.....lol
Old Sep 2, 2013 | 03:59 AM
  #765
1nate7's Avatar
245/35/18, and you are going to want a decent amount of negative camber. I'd say minimum of -2.5.
Old Sep 2, 2013 | 08:44 PM
  #766
saal's Avatar
just installed my pf01
17x8 +50 front
17x9 +60 rear
getting some BR Coilovers very very soon, dropping 1inch or so
Old Sep 2, 2013 | 09:03 PM
  #767
v10killer's Avatar
What about pulling with a roller just a couple millimeters is that possible
Old Sep 28, 2013 | 12:41 PM
  #768
dagle's Avatar
Anyone know what it takes to fit
255/40/17 on a 17x9.0+45 up front? (Hankook's RS3 or Dunlop's ZII StarSpec)
I have Varis CF fenders that are 15-20mm wider, but the previous setup I had on there still rubbed on driveway entry. The previous was 225/45/17 on 17x9.0+42. Ride height is about lowered about 2", but I can adjust that as needed.
FR camber's -1.0* and RR at -2.0* atm on my lifetime alignment. Been looking at going FR -2.0/ RR -3.0 but I'm still unsure how much space I'll be getting. Basically what I'm asking is that with 15mm wider fenders and more camber, would I have a shot at clearing? Would like to avoid buying OEM/DF fenders but I do want to run a meatier tire up front. Thanks in advance!
Old Sep 28, 2013 | 01:33 PM
  #769
s2000Junky's Avatar
The fact that you have 15-20mm wider front fenders should make this a snap. -1 camber is quite conservative coupled with a low ride height is the only explanation, that and driving habits. But I'd say if you are no more then 12.75-13" from fender to center bore aka 2" drop, you should not rub any more with -2 ish camber. A 255 has no pull on the sidewall with a 9" rim, its slightly bulged/flat so there is no sidewall tuck as the suspension cambers as it compresses, so you need more static camber to tuck it.
Old Sep 28, 2013 | 02:13 PM
  #770
dagle's Avatar
Thanks for the input! I'll see if I can take a measurement and check the drop before reporting back. Sure beats the hell out of dremeling CF fenders lol
