Wheel Fitment Guide
Old Nov 30, 2013 | 09:06 PM
  #781
Dat956Boi's Avatar
18x8 +40 front and 18x9.5 +40 rear if dropped about 1 or 1 in a half inch, what would the best tiers size be for this setup??
Old Dec 1, 2013 | 07:24 AM
  #782
1nate7's Avatar
225/40, 255/35 and requires rolled fenders.
Old Dec 2, 2013 | 10:52 AM
  #783
Dat956Boi's Avatar
Thanks again >
Old Dec 5, 2013 | 10:15 PM
  #784
JrsS2000's Avatar
17x7.5 +40 with 17x8.5+40 or 17x9.5 +40?
Old Dec 6, 2013 | 07:17 PM
  #785
waldrop405's Avatar
17x9 +45 with 245/45 rear 225/45 front and 2 degrees camber front and 3 in the rear. I want to be flush but I rub really bad in the rear already at about 1.5 finger gap. What can I do to solve to rubbing so I can go lower?
Old Dec 7, 2013 | 03:58 PM
  #786
joey77051's Avatar
17x8.5 +40 all around. will 255/40/17 all around fit? My front and rear fenders are rolled and on stock height
Or should I purchase 225/45/17 and 255/40/17 combo? any inputs?
keep in mind my car is not lowered!
Old Dec 7, 2013 | 04:31 PM
  #787
Bloody Hatch's Avatar
got a quick question for the fitment gurus, I've found a set of CCW reps with the following specs: 17X8+35 and 17X9+35.
Right now, I'm running the stock wheel/tire specs on my AP1 with a 1" drop from eibach springs. I don't mind a small wheel gap but definitely not looking to be slammed. I don't autocross and this is my DD.
What would you guys suggest on tire size for this setup?
Old Dec 11, 2013 | 12:34 PM
  #788
deception9's Avatar
the 8.5 is going to be much easier to fit. i (essentially) had 8.5 +40 on my rear with 245, replaced my worn out tires with 255s and had to remove the spacers, so back to stock offset.
with the 9.5 you could likely get a slight stretch with a 255, for sure with a 245.
yes, 255 all around will fit at stock ride height. but lower it considerably and you will have problems. a slight drop you should be fine. may want to read up on the nonstaggered guys handling thread, most highly recommend a change in roll bars to make the car more neutral after a square set up.
don't get replica wheels. pressure cast wheels are shit, and 99% of reps or fakes are pressure cast. you should be looking a forged wheels. that being said, 9+35 looks good in the rear but requires a bit of work if you want to be finger gaps away from the fender. tires i'd go 225 front 245 rear. you could try a 255 but you'lll have to be pretty high.
raise your car. get new tires with a smaller measured width. roll the fenders. get an alignment and add more camber. pull the fenders. all possible options.
Old Dec 13, 2013 | 12:05 PM
  #789
joey77051's Avatar
thanks for the help! will report back once I installed tires
Old Dec 15, 2013 | 03:49 PM
  #790
joey77051's Avatar
Installed 255/40/17 conti DW on 17x8.5 +40 wheels all around with rolled front and rear fenders on stock height! No rubbing at all even at full lock turn, bump...etc
