Wheel Fitment Guide
Old Jul 3, 2014 | 05:53 AM
  #861
alan168's Avatar
Any ideas if I could get 235/45/17 rsr on the te37 17 x 7.5 et30 with asm front fenders? ?
Old Jul 23, 2014 | 04:29 AM
  #862
DaGou's Avatar
Originally Posted by Im One To Envy
Alright guys I finally got my wheels picked out, went for something that will be a little less tough to fit. I just wanted to see what you guys think before I order them tomorrow. Enkei TS6 18x8.5 +30 w/ a 215/40 up front and a 18x9.5 +35 w/ a 225/40 in the back. Car will be almost slammed on BC Racing BR series coils with the extreme low springs.
I think it will look okay hard parked(if you are going for the stance nation look), however I would not want to drive it. A 18X9.5 +35 even with 225 is going to stick out over a inch. Your rear fender will be touching or almost touching your tires depending on your slam. Again if that is what you are going for you got it. Just do not drive the car, go over bumps, and take corners at less than 20 MPH and you will be great. Congrads on distroying all driving enjoyment. But hey it will look great parked. Good luck with your build.
Old Aug 8, 2014 | 07:02 AM
  #863
Danu_32's Avatar
It's seems to be nearly impossible to find black 17x8 (front) and 17x9 (rear) wheels with the correct offsets.
Any help would be appreciated.
Thanks
Old Aug 11, 2014 | 10:21 AM
  #864
deception9's Avatar
Thanks
enkei RFP1s come to mind 8+45 and 9+45. you could run anything around there. Wedsports TC103 are another 8+49 and 9+49 in black. there are actually tons of wheels, some are just more work than other. even with a +45, most people roll their fenders (for good reason)
Old Aug 11, 2014 | 10:29 AM
  #865
Danu_32's Avatar
Thanks for the reply.
Looking at a set of 18x8 +45 front 18x9.5 (or x9) +45 rear, with 215/40 and 255/35. With rolled fenders, would that set up work?
Old Aug 14, 2014 | 03:02 PM
  #866
Dat956Boi's Avatar
I found some nice wheel's for a far price and im wondering if the offset can work ok.. 18x8.5 +38 front and 18x9.5 +35 rear . What is a good tire for the rear that will let the car be dropped One inch and not rub i know i will have to roll fenders.
Old Aug 18, 2014 | 10:15 PM
  #867
ALaS's Avatar
What about 17x9 +40 CE28n's on 4 255/40/17? I am concerned with the rear, as I will buy flared fenders. Need I to worry?
Will be on Tein MonoFlex
Old Aug 19, 2014 | 08:26 AM
  #868
Manga_Spawn's Avatar
Site Moderator
You will need a roll, tab relo, bit of a pull in front and probably -2.5 front and -3 rear camber. I would run a 225 front and 245 rear for a little extra clearance.
You should be worried about the front unless you mean you are buying wider front fenders. The rear will fit with the standard roll, tab relo and camber but the front will need a roll and pull and probably -3 camber.
Old Aug 20, 2014 | 09:50 PM
  #869
ALaS's Avatar
I will run the 30mm wider front fenders. I was hoping to get away with no rolling in the rear. It's not possible to squeeze a 255 back there cleanly?
Old Aug 20, 2014 | 10:12 PM
  #870
Danu_32's Avatar
Here are 18x9 +40 on 255/35's that I just put on probably not the best pic. If I go any lower I will def need a roll:
Attached Thumbnails Wheel Fitment Guide-image.jpg   Wheel Fitment Guide-image.jpg
