Wheel Fitment Guide
Old Feb 17, 2015 | 08:26 AM
  #941
Manga_Spawn's Avatar
Site Moderator
Yes. All you need is a roll and tab relocation. You shouldn't much negative camber over stock once the fender work is done.
Old Feb 17, 2015 | 09:57 AM
  #942
RQs2K's Avatar
Appreciate that! Many thanks.
Old Feb 17, 2015 | 10:37 AM
  #943
Th0R's Avatar
Hey,
I have a inquiry:
will i rub with the following specs at the front?
Ce28n 7.5x17 et50 with drs 10mm h&r spacers = et40
My car will be lowered to a 1 finger cap.
Old Feb 17, 2015 | 10:52 AM
  #944
DrakeValle's Avatar
The guy just a few posts above you asked about the same setup on the front. You are going to want to roll the front fenders.
Old Feb 17, 2015 | 12:19 PM
  #945
Site Moderator
Originally Posted by Th0R
Hey,
I have a inquiry:
Yes. You will need to roll the fenders.
Old Mar 1, 2015 | 06:15 PM
  #946
kahn_v's Avatar
S2k wheel fitment noob here and have no idea where to start lol.
Will be going ASM rear fenders with spoon fenders up front. I want enkei rpf1's, I would like to have the best handling possible from my wheel setup and if possible achieve a decent level of fitment and stance. What width/offset and tyre sizes do you veterans recommend? Any help appreciated!
Old Mar 2, 2015 | 08:45 AM
  #947
Site Moderator
17x10 +38 all around with 255's all around. You will need to dial the camber in but it should fit with the wider fenders. That is what I would do.
Old Mar 2, 2015 | 10:05 AM
  #948
kahn_v's Avatar
Sweet. How do you reckon it'll handle on 10s?
Old Mar 2, 2015 | 01:06 PM
  #949
Site Moderator
Define what you mean by handling? There is threads in the R&C showing that a 10 inch wide wheel is better for the track than 9 inch wheel with the same tire and same wheel. But that is on the track. If you are asking about street or something its a different question. Steering will be heavier and you may want a stiffer front sway bar depending on the model year of your S2000. You can always do 10 int he rear and a 17x9 +30-35 front if you want to keep some stagger. Run a 245 front and 255 rear.
Old Mar 3, 2015 | 03:30 AM
  #950
kahn_v's Avatar
I have a 2004 model. With regards to the handling, the car will be mostly street driven with say 5 or 6 track days a year. So mostly street. In this case would you recommend a square setup or keep some stagger?
