Wheel Fitment Guide
Old Apr 11, 2015 | 04:13 PM
  #981
Manga_Spawn's Avatar
Site Moderator
You need to roll all the fenders and relo the tab.
Old Apr 12, 2015 | 09:27 AM
  #982
Mish's Avatar
hey all,
Please excuse the ignorance, I know nothing about wheel size/offsets etc.
Can I fit the following without fouling/rubbing etc and is this a good size/offset to go with...
Front - 8" x 17" +55 offset / tyre 215/45R17
Rear - 9" x 17" +65 offset / tyre 245/40R17
I want to keep rolling radius as close as possible to OE and also keep the wheel 'positioning' as close to OE as possible too.
Thanks
Old Apr 12, 2015 | 09:36 AM
  #983
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Best set-up.
I would go 255/40R,and 225/45F.
Old Apr 12, 2015 | 09:46 AM
  #984
Mish's Avatar
but with the front +55 and rear +65 offset as stock Emil?
Old Apr 13, 2015 | 07:58 AM
  #985
Site Moderator
Originally Posted by Emil St-Hilaire
Best set-up.
Yup this should fit easily with those high offsets. No fender work needed.
Old Apr 13, 2015 | 08:01 AM
  #986
Mish's Avatar
thanks manga... i'm so wary of making mods if not sure... glad so many helpful people on here.
I'm right in saying with those offsets, the wheels will stick out slightly more and also be further in slightly more (due to the width, but it should be by about equal amounts.
Looking at the OE wheels on the car, its difficult to judge how they will look as there doesnt seem to be that much more it can stick out before being outwith the arches, but going on some of the sizes people have fitted, looks like there is more room than you think.
Obviously I dont want the wheels fouling on the inside edge either haha.
Old Apr 13, 2015 | 08:39 AM
  #987
Site Moderator
Yes they will be slightly different but not enough to matter.
http://www.willtheyfit.com
Front
Compared to your existing wheel, this new wheel will have an inner rim which is 12.7mm closer to the suspension strut. The outer rim will poke out 12.7mm more than before.
Rear
Compared to your existing wheel, this new wheel will have an inner rim which is 6.4mm closer to the suspension strut. The outer rim will poke out 6.4mm more than before.
Old Apr 13, 2015 | 09:40 AM
  #988
Mish's Avatar
thanks Manga... does anyone know exactly how much 'room' there is to play with front and rear on the inside and outside or is it not possible to work out?
Old Apr 14, 2015 | 08:21 AM
  #989
Site Moderator
Ask junky. He has measured that. The fronts are harder because the wheel turns so even with conservative offset you need to be careful as it can grab.
Old Apr 14, 2015 | 08:37 AM
  #990
Mish's Avatar
thanks Manga... do you have a link to his profile? Cant find him on the search.
Hopefully there will be enough room for 8 x 17 fronts with that offset on full lock.
