Wheel Fitment Guide
Originally Posted by ALaS' timestamp='1408600249' post='23295577
You should be worried about the front unless you mean you are buying wider front fenders. The rear will fit with the standard roll, tab relo and camber but the front will need a roll and pull and probably -3 camber.
Danu,
That is kind of close to the size I just ordered and am worried about fitment issues,
I'm getting :
Front 18X8 w/+40mm and 225/40-18 tires
Rear 18X9.5 w/+40mm and 245/35-18 tires
What did you have to do to your fenders to fit?
Do you get any rubbing, if so under what circumstances?
My car is not lowered.
Your car looks great!!!
Thanks for your anticipated help...
Originally Posted by Danu_32' timestamp='1408601579' post='23295584
[quote name='ALaS' timestamp='1408600249' post='23295577']
I will run the 30mm wider front fenders. I was hoping to get away with no rolling in the rear. It's not possible to squeeze a 255 back there cleanly?
Danu,
I'm getting :
[/quote]
With those specs you need a full roll on all the fenders and rear tab relo and camber.
You don't want to run either. The First set is to narrow to be an upgrade and will look like crap and the second set isn't even really an upgrade from AP1 OEM wheels so why bother. Sell both and buy wheels that are either AP2 oem specs or an improvement on those specs.
Originally Posted by Frank' timestamp='1411283236' post='23338975
[quote name='Danu_32' timestamp='1408601579' post='23295584']
Danu,
I'm getting :
[/quote]
[/quote]
ALL OF THIS. Manga_Spawn bringing the wheel and tire HEAT/ dropping mad knowledge. Now that's a bad ass mod right there
