Wheel offset question, etc.
Originally Posted by jeffbrig,May 19 2009, 04:13 PM
My fronts are identical to yours, but in 17s. My rears are 17x9 +63 with a 255 tire. This setup has never rubbed for me.
Your narrower rear rim would gain you ~6mm of clerance, but you give up 8mm in offset, so a net difference of 2mm compared to mine. Unless 17 vs. 18 sizes make a big difference in the edge profile shape of the tire, I don't see this being a problem.
My car is lowered about an inch on Bilstein pss9 coilovers. Spring rates are 345/285, IIRC. Not sure how that compares to Eibachs (stiffer spring = less suspension travel).
Hope that helps...
Hope that helps...
Another one...
Rims don't rub...tires do.
The offset determines where the center of the tire is located, just like it determines where the center of the wheel is located. So if you know where the center of the tire tread is located and how wide the tire is, you can predict if it will rub or not.
With only 40mm offset, you won't be able to run much over a 235 without rubbing. That is about as small a tire as you want to run on an 8" rim. You might get away with a 245 but it would depend on the tire.
If you get 255s for the back on 40mm offset rims and they don't rub, I will delete both my posts in this thread and eat my hat.
Originally Posted by tof,May 19 2009, 03:32 PM
The table is a good guide, and wheel width doesn't really matter. Here's why: Wheel width doesn't matter...TIRE width does.
That said, tof is right, the wheel offset will be the primary variable in locating the center of the tire. A narrow wheel will pinch the tire a little, but it won't be a 1:1 ratio changing the width of the tire at the point where it can rub. So, that 6mm gain from the narrower rim I was predicting above is going to be less than 6mm.
(tof, thanks for helping my understanding on that)
OK, but lets remember that the point where a tire rubs is USUALLY around the outside tread edge. That point doesn't vary as much with rim width as other sections of the sidewall. And the variation in sidewall width from one rim-width to another is still much less than the variation from one tire size to another (10 MM increments). In fact it is probably less than the variation between different brands and models of tire. So the tread width rating is still the only useful wheel/tire parameter in determining if a given setup will rub or not (again, assuming you don't go nuts and put something with a larger diameter like a 245/55 on the back.)
(jeffbrig, thanks for saying I was right about something. I don't get that very often
ps: and always listen to Jim from TheTireRack because he is one pro who knows his s**t.
)ps: and always listen to Jim from TheTireRack because he is one pro who knows his s**t.
