wheel size help
Old Nov 7, 2007 | 08:34 PM
ronaldng0809's Avatar
Default wheel size help
hello, anyone know if 18x8 +45 for the front and 18x9 +45 for the rear fit without any problems. and if it will fit, what size of tires do i need for the front and rear. thanks a lot
Old Nov 7, 2007 | 08:44 PM
Sinji's Avatar
it will fit, however you have to run some camber and roll the rear fender especially if the car is lowered. you can run 225 and 255 respectably but most would recommend 245 for the rear. run at least 2.5 in the rear and 1.5 for the front camber and you should be fine.
Old Nov 7, 2007 | 08:54 PM
silentdancer's Avatar
to be on the safe side if you are planning on lowering without rolling the front fenders i recommend a 215
Old Nov 8, 2007 | 04:24 AM
Jim@tirerack's Avatar
Former Sponsor
Those offsets are aggressive and will require some work to make them fit. I would say 245/35R18 would be easier to fit on the rear with the 215/40R18 on the front.
If I can help let me know.
Old Nov 8, 2007 | 07:37 AM
245/35R18 at the rear and 215/40R18 at the front. so if i get this tire size,i dont need to roll fender and camber kit right??
06S2000speed
Dec 19, 2009 11:59 AM
b20teg
Jul 15, 2008 06:36 AM
JBrakeS2K
Dec 23, 2007 09:57 AM
octechgeek
Oct 1, 2007 01:03 PM
Kel
Mar 21, 2005 11:10 AM
