Wheel Stud length and spacers
Old Apr 29, 2007 | 08:22 PM
SoCalIsMyLife's Avatar
Default Wheel Stud length and spacers
Two quick questions: How far do the studs stick past the rotor in the back? I'm getting spacers and need them to stick past the old studs. Second, any major problems with running a big spacer, like 1" or 1.25"?
Old Apr 30, 2007 | 05:25 AM
minh's Avatar
1" = 25.4mm
wouldnt that lower your wheel's offset too much? if your wheels are +65, with the spacer your wheels would now be ~+40
Old Apr 30, 2007 | 08:46 AM
pitstops's Avatar
some cars even with a 5mm spacer the front wheel vibrates how is it on the s2000?
Old Apr 30, 2007 | 11:09 PM
so minh u're saying they stick 1" past? i want to make sure i buy a spacer big enough
Old May 1, 2007 | 05:08 AM
minh's Avatar
yeah if you put a 1" spacer in, your wheels will stick out 1" further
what size wheels and offset are you planning on using the spacers for?
i've never used spacers before so you might want to consult with members on this board who has to see if there are any problems with running spacers that big
Old May 1, 2007 | 06:22 PM
JeremyM's Avatar
ive got 20mm's and i had to cut down the stock lugs a bit for them to fit, no biggie only takes a few minutes.
Old May 1, 2007 | 07:32 PM
no i meant if i got 1" spacers will the spacer be thicker than the length of the original studs. I have a wide body that I am trying to use slipstreams with and therefore need a 1" spacer, since my current wheels are 2" wider with the same offset.
Old May 1, 2007 | 07:33 PM
do u have any photos of your car with the spacers?
Old May 2, 2007 | 05:52 AM
minh's Avatar
oh i see, i misunderstood your post, my bad
johnckeen
Jun 11, 2018 04:44 AM
DesiS2k
Mar 22, 2011 05:05 AM
S2K Driven
May 13, 2009 10:24 AM
MIAMI S-2000
Apr 28, 2008 07:49 AM
