Why do wheels have a hole for the center cap?
Old May 3, 2013 | 12:48 PM
indopinoy's Avatar
Default Why do wheels have a hole for the center cap?
In my usual state of lost thought during my commute, I came across this question:
Why do wheels have a hole in the center, where the center cap goes?
As I'm too busy at work right now to search/research this, I thought I'd pose the question to the masses. Is the center cap hole merely there to accommodate the center cap? Or maybe the hole is part of the manufacturing process?
Why aren't wheels manufactured hole-less?
And why is this question making me crave donutholes?
Old May 3, 2013 | 12:54 PM
Manga_Spawn's Avatar
Site Moderator
They use it when balancing the wheels. Also probably has something to do with the hubs on the car. You can check the hub without removing the entire wheel.
Old May 3, 2013 | 05:59 PM
Jet3010's Avatar
This is correct. Although you can balance wheels without a balance machine it is far more accurate than other methods.
Old May 4, 2013 | 08:05 AM
jst2878's Avatar
Plus, you can re torque the rear axle nut with the tire on
Old May 6, 2013 | 05:14 AM
fatjoe10's Avatar
I believe it is there for manufacturing purposes. I'm no expert, but what other way would they be able to spin the wheel to make sure that it runs true regardless of the balancing?
Old Apr 15, 2021 | 06:01 PM
Fullmetal Crazy's Avatar
Speaking as one who worked in a tire shop for 6 years, unfortunately you will never find a wheel that is perfectly balanced. Which is one of the reasons you need wheel weights.
But I believe you are correct, as we'll as needing the hole in the center to balance the wheel/tire assembly.
Old Apr 16, 2021 | 11:17 AM
starchland's Avatar
The hole is for the centre cap to go in
Old Apr 16, 2021 | 12:30 PM
Site Moderator
8 year old thread is 8 years old.
spakky
Apr 15, 2021 06:04 PM
crfloyd
Dec 21, 2010 12:48 AM
SickShift
Oct 6, 2009 01:23 PM
Jack_in_the_Box
May 7, 2009 08:00 PM
krisl
Apr 12, 2006 04:21 AM
