why is it so difficult to set the alignment to preferred UK specs.?
Old Aug 22, 2002 | 03:12 PM
ohmoana's Avatar
I've given this one shop the preferred UK alignment settings for optimum steering/suspension twice now and they just can't seem to set the caster, camber OR toe near those specs. Is the difference significant or not?
For example........
UK Optimum Spec. / what they set
Front Right Caster: 6.45" / 4.60"
" Left " 6.45" / 3.90"
Total Toe: .040" / .20
The mechanic told me that although the machine only registered the above settings for the caster, he continued to manipulate the tire (and to see it continue moving, he said) and had to "eyeballit" to where he believed 6.45" would be.
I feel this guy hasn't much experience aligning these cars and that maybe they just can't do it. Any thoughts or similar experiences would help as I'm taking it back for the third time in a day. Thanks, Holly
Old Aug 27, 2002 | 07:22 AM
Schatten's Avatar
the camber is difficult to reach to the max #'s while everything else is optimal. anything close to 6 and up should be fine, and I really don't believe you'll notice a difference.
although I'm not sure about the "UK Specs", I typically go with the following:
F -1.5 camber / 0 toe / +6 caster
R -2 camber / 1/8 to 1/4 toe IN
There's lots of other thoughts and theories located in the "Under the Hood forum.
Hope this helps!
zeroptzero
Apr 19, 2015 04:07 PM
Nate03
Dec 2, 2005 08:40 AM
honda606
Jun 15, 2004 10:49 AM
mikecl713
Apr 3, 2004 07:24 AM
dlq04
Oct 28, 2003 03:36 PM
