Will these fit the S2K?
Old Feb 18, 2003 | 07:29 PM
Carlson's Avatar
Default Will these fit the S2K?
-17X8 45 offset, 215/45/17 tire, DIA 24.6"
-17X9 63 offset, 255/40/17 tire, DIA 25.1"
Stock height. May lower a bit (1") in the future.
Thanks.
Old Feb 18, 2003 | 07:44 PM
Carlson's Avatar
Come on experts, need your help!
Old Feb 19, 2003 | 06:52 AM
Jim@tirerack's Avatar
Former Sponsor
Yes they will fit. I would recommend a 225/45R17 myself. That would keep you in the correct height front and rear.
If you have a lower offset wheel the 215/45R17 would help some.
Let me know if I can help with the tires.
Thank you
Jim 800-428-8355-364
Old Feb 22, 2003 | 10:23 AM
schwett's Avatar
as jim said, that rubber setup has a smaller front diameter than rear, which is backwards. you've got a big enough difference there that i would look at smaller rubber on the rear or larger on the front.
coop3422
Mar 10, 2016 05:24 AM
S1LV3RS2K
Apr 23, 2008 06:45 AM
S9735
Mar 28, 2005 12:24 AM
nureulwihaesuh
Sep 29, 2004 12:19 AM
sperry
Dec 30, 2001 01:25 PM
