Guage cluster is flickering.... :(
Old May 12, 2006 | 10:06 AM
SiCK HONDA's Avatar
Thumbs up Guage cluster is flickering.... :(
Hey guys-
I recently had a Comptech S/C installed and this problem seems to be linked...
The guage cluster will "flicker" while at idle or very low RPM's... As soon as the RPM's go up-- The problem goes away...???
Any Ideas?
Thanks,
Matt
Old May 12, 2006 | 10:08 AM
FormerH22a4's Avatar
battery?
Old May 12, 2006 | 10:15 AM
SiCK HONDA's Avatar
Is the car pulling power from the battery when at idle? Is the alternator only producing power when under load??
I always thought you could pull the battery out once the car was running, and it would run until you shut it off?
-Matt
Old May 12, 2006 | 10:32 AM
darkfx's Avatar
replace your alternator to fix the issue. For some reason, if you have autozone run a test on it, but it will still come back fine.
Old May 12, 2006 | 01:58 PM
r_duff's Avatar
i'd replace the battery before i get to the alternator. If it doesnt fix it, then return the battery and move on to the alternator.
Old May 12, 2006 | 02:36 PM
Mr. Eryozgatliyan's Avatar
Banned
i don't think that you can return battery's man
Old May 12, 2006 | 03:23 PM
darkfx's Avatar
I'll bet anyone a tasty lollipop its not the battery but the alternator
Old May 12, 2006 | 03:26 PM
r_duff's Avatar
most shops dont after u install it.... just lie and say u never installed it.
Old May 12, 2006 | 04:49 PM
s2kBryan916's Avatar
I think you need to do some more tests to figure out what it is. Or you can do the shotgun method and go buy a bunch of stuff and see if it fixes it.
Old May 16, 2006 | 01:06 AM
zenkai_ate_you's Avatar
i have pretty new optima yellow top but my car doing same s0it man..
tell me if you fixed this problem already..
