How to convert toe in inch to degrees ?
Old Jun 26, 2007 | 08:17 AM
OOH-VAE's Avatar
Default How to convert toe in inch to degrees ?
The recommended auto-X alignment setting for rear toe is 1/4" to 3/8". How much is that in degrees What is the formula to convert it ?
I did some calculation assuming it's measured at the lip of the rim. That came out to 1.7 degrees equals 1/4 inches. Where are the mathmaticians that teach "trigonometry for autocrossers"
Old Jun 26, 2007 | 08:26 AM
krazik's Avatar
Administrator
Search for "toe degrees" in the search this forum box at the bottom. Been discussed many times. The quick and simple answer is deg/2 = inches. Tho the -actual- calculation is more involved than that if you care about 4 digit resolution.
-Ry
Old Jun 26, 2007 | 08:31 AM
E-Z's Avatar
E-Z
It's simple math. Numerator divided my denominator.
1/4"
convert to decimal
1 divided by 4 = .25
1/8"
converted to decimal
1 divided by 8 = .125
1/16"
1 divided by 16 = .0625
Oh BTW, most alignment machines will do both. I say most, buy maybe all as I haven't seen on that doesn't do both.
Old Jun 26, 2007 | 09:19 AM
OOH-VAE's Avatar
Thanks Krazik, I found the thread that had the formula to calculate the degrees:
sin toe [degrees] = toe [inch] / tire diameter [inch]
For example: 1/4'' = 0.58 degrees
E-Z, I think you should check your alignment Your math is off by factor 2.
Old Jun 26, 2007 | 10:12 AM
E-Z's Avatar
E-Z
ahhh.... I guess I misinterpreted your question. LOL
Old Jun 26, 2007 | 10:30 AM
krazik's Avatar
Administrator
Like I said. degrees/2 = inch
Old Jun 26, 2007 | 01:28 PM
dnace's Avatar
thank you finally someone who got it right!!! A lot more invovled than most think.
Old Nov 11, 2007 | 11:00 PM
Davidss's Avatar
Sorry to bump an dead thread but if you search for "toe degrees" this thread comes up. Just thought I would post a table of toe in degrees and inches for stock S2000 sized tires (24.9 inches) and save people the trouble of busting out the old scientific calculator:
Toe in Inches = Toe in Degrees
1/16 = .14
1/8 = .29
3/16 = .43
1/4 = .58
5/16 = .72
3/8 = .86
Also the above 'simple' formula is a bit off. It is much more accurate with 2.3 instead of 2 as the magic number:
Toe in Inches * 2.3 = Toe in Degrees
Toe in Degrees / 2.3 = Toe in Inches
Old Mar 20, 2013 | 04:32 AM
robrob's Avatar
This is an old thread but Google brings it up for "convert toe degrees to inches" so I thought I'd link to two calculators I put online. The web page calculators will convert toe inches to degrees and convert toe angle to inches at 1 wheel or total toe for the axle. You input the tire diameter and toe to get an answer:
Convert Toe Inches to Degrees: http://robrobinette....esToDegrees.htm
Convert Toe Angle to Inches: http://robrobinette....eesToInches.htm
The Shop Manual 0.25 inch rear total toe = 0.29 degrees per wheel or 0.58 total rear toe-in with the stock size tires.
blacktie
Apr 14, 2009 03:55 AM
Spa4eva
54
Apr 8, 2006 09:45 AM
Random1
Jan 3, 2005 08:28 PM
fin man
Sep 14, 2004 05:12 PM
tmorrow
Apr 11, 2004 09:27 PM
