Throttle Position Sensor signal DBW
Hi..
I'm trying to guess where to find the TPS wire on a DBW S2000 (MY08)
The sensor is not located where the non-DBW sensor is located.. but I assume that somehow the TPS information is needed and that the signal should be available somewhere
What I need is a 0..5V signal (5V full open and 0 full closed for example)
I need to it to tap it into a Innovate LMA-3 Interface.
Any help would be appreciated. I have tried to used the search but I did not find a direct answer to it.
Thanks!
Thanks!
I have "found" this sensor
it's not really a TPS but a "accelerator pedal position sensor", so I suppose that this sensor is used by the ECU to decide how much to open or to close the throttle body..
The TB itself must have somewhere a wire that indicates how much the TB should be opened or closed.. (that's what I am searching)
But I don't have any DBW TB wiring diagram (or the accelerator pedal sensor).. does someone have it? (Helm's manual maybe?)
Originally Posted by deibit,Sep 2 2010, 04:52 PM
yeah.. but which of each of the 6 wires does what?
(i need the pinout diagram...)
Thats a start.
J
