AEM V2 start up setting
Old Sep 4, 2011 | 07:33 PM
s2knoob89's Avatar
Default AEM V2 start up setting
Need some help with the start up setting in the AEM V2. My problem is sometimes when I crank the motor over the RPMs will shoot up to like 3k and then drop back down to idle. I know this can't be good for the motor?
So my question is what setting do I need to start adjusting in order to fix this? Can it be fixed?
Old Sep 4, 2011 | 09:36 PM
jh4db536's Avatar
Consider two tables:
Idle target base
Rpm offset vs start (this is the one that is set too high I bet)
Sent from my T-Mobile G2 using Tapatalk
Old Sep 5, 2011 | 04:49 PM
EliteTuning's Avatar
Definitely your idle % vs target, idle target base, rpm offset vs start & also check your idle trims
Old Sep 6, 2011 | 06:51 PM
s2knoob89's Avatar
RPM offset vs start was set too high. Thanks guys.
beefystud
Mar 2, 2019 08:14 AM
nemesisryder0627
Feb 25, 2018 11:59 AM
AWWHITE s2k
Nov 3, 2012 03:45 PM
FX07
Feb 18, 2009 01:16 AM
fromSStoS2
Aug 13, 2004 11:30 AM
