Prepping for BSP
Old Dec 14, 2011 | 09:50 AM
steguis's Avatar
Default Prepping for BSP
I was reading the latest issue of Sportscar last night and it got me thinking, my car with a few changes could be BSP legal. I'd need to remove the wing and maybe replace it with a mugen duckbill spoiler and ditch the splitter (but could replace it with a CR lip). I don't have a soft top anymore but wouldn't that be covered under backupdate/update or do I need to do a full CR conversion for that to be ok? It's interesting because S2000s are listed as a single line the SP category so they don't distinguish AP1 vs AP2. Does that mean I can mix and match parts between AP1/AP2/CR as needed? Other than that, I'm guessing my haltech standalone would still be ok, same for my steering wheel (no airbag). Oh I'd probably have to put a non-vented hood back on too. Brake ducts are ok?
Old Dec 14, 2011 | 11:19 AM
CKit's Avatar
I think you'd need CR tonneau and rear cross brace, IIRC.
I have a hybrid of Tipple and Uyeda's 2007 BSP S2000 Nats setups if you have any questions. They were the last real competitors at a National level. I have a set of John Ward's BSP wheels from 2009, too.
Old Dec 14, 2011 | 01:10 PM
steguis's Avatar
What size wheels are those and what tires did they run? I assume I'd need to put my interior behind my seat back too which I don't think I can do because I've got the cross bar and bulkhead replacement in there for the harddog rollbar.
Old Dec 14, 2011 | 02:18 PM
MattP's Avatar
You should check the wording of the roll-over protection changes in Stock class for 2012, that may limit what you need to reinstall.
Old Dec 15, 2011 | 06:16 AM
mLeach's Avatar
The bulkhead will be a deal breaker. That needs to be stock. With regard to UD/BD, you can mix and match except for the engine and tranny assemblies. Those have to be whole.
I like the idea of BSP. I don't like the idea of Hoosieriti$.
Old Jan 5, 2012 | 03:41 PM
iLuveketchup's Avatar
Bump! Since the Evo is out to ASP, I think the s2k will be fun in BSP. So if the car has a roll bar w/ interior bits in place (although no softtop), will it pass BSP?
Old Jan 5, 2012 | 04:50 PM
steguis's Avatar
Clyde, after doing more research you'd have to do a proper CR conversion if you want to go BSP which means putting the interior panels back in and getting the CR tonneau cover.
Old Jan 5, 2012 | 05:16 PM
That's not a problem. They fit with the roll bar in place. My only concern is my side mirrors. Also I think the s2k is in CSP for '12.
Old Jan 5, 2012 | 05:33 PM
steguis's Avatar
Yeah, you're gonna have to put back the stock side mirrors and of course ditch the wing. Other than that you have a perfectly SP legal car. ECU, test pipe, etc, are good to go.
Old Jan 5, 2012 | 05:50 PM
hmm... the mirrors might be trouble. But I wouldn't mind ditching the silly wing.
