Speed sensor code No VTEC
Old Nov 20, 2012 | 01:41 AM
sunnyS14's Avatar
Default Speed sensor code No VTEC
I just recently got this car and it threw a CEL p0500 which comes out to be a VSS malfunction. Changed the sensor and the code still pops up, no VTEC either. Gauge cluster reads fine but the car hits a brick wall at 7000rpm...
Any ideas?
Old Nov 20, 2012 | 02:14 AM
sunnyS14's Avatar
Speedometer works, along with cruise control also if that helps.
Old Nov 20, 2012 | 03:45 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you just got the car, inspect it for a device called a yellow box. This may be causing your problem.
The ground wire on the back of the cylinder head is also directly responsible for VSS issues.
Old Nov 20, 2012 | 12:12 PM
sunnyS14's Avatar
Ground on the back of the cylinder head looks and feels intact.
Is there a possibility that the VSS signal isn't getting to the ECU?
Old Nov 20, 2012 | 12:21 PM
Billman250's Avatar
Top Answer: 1
Another possibility is an improper "top down while moving mod" done to the car.
Plug a scan tool in, and see if the VSS comes up on the scanner.
trackrabbit21
Aug 10, 2022 04:44 PM
I_s2k1
May 31, 2013 04:23 PM
Vinsfeld
Mar 4, 2013 04:05 PM
Jonzyy
Aug 25, 2012 11:50 PM
JDM Spoon AP1
May 1, 2006 08:39 AM
