Why you should change your clutch...
Old 05-09-2009, 06:19 PM
e39m5's Avatar
Default Why you should change your clutch...
I bought my car used with 104,000 miles. I knew the clutch was last replaced two years ago, but I assumed it still had a bit of life. The previous owner ripped it while demoing.
The other day I was cruising on the highway, got off, and couldn't get into gear. I wasn't really doing anything special, nothing out of the ordinary, but I couldn't shift.
From the noises it was making we guessed it was just the throwout bearing. We were wrong...
Summary: a pair of springs ripped out of the disc. The larger, outside spring got broken up into a bunch of pieces. The smaller, inside spring got lodged in the pressure plate.
I noticed that the clutch pedal became a lot less stiff, but I assumed it was the bearing. Guess I was wrong.
$730 in parts and labor later, my car is good as new for a great price.
I'm pretty sure none of this would have happened if I had changed the clutch. There is very close to 0 friction material left.
e39m5
Old 05-09-2009, 06:24 PM
RedY2KS2k's Avatar
You're correct: if you had spent $730 on parts and labor (a great price, I might add) to change your clutch you wouldn't have had to spend $730 parts and labor to replace your clutch a bit later.
Old 05-09-2009, 06:26 PM
teanza's Avatar
same thing happened 2 my 'z'!
~tina~
Old 05-09-2009, 07:25 PM
Artric's Avatar
You said exactly what I was going to say.
Old 05-09-2009, 10:04 PM
SoMe0nE2tAlK2's Avatar
might i ask where you got the parts for so cheap?
Old 05-10-2009, 08:20 PM
Jsmply's Avatar
I agree. That is a VERY good price for a clutch job for parts AND labor. Anyone else getting them this cheap?
steveSC2
08-27-2013 06:26 AM
tozerman
03-22-2012 10:58 AM
s2kevx
10-25-2010 12:52 PM
nismo300zx
03-03-2009 09:35 PM
Quick Reply: Why you should change your clutch...
