Urge/Ohlins TTX36 Initial Thoughts...
From the start I knew I should be looking at suspension to be more successful on the track. When I finally took the plunge late in 2014, the result was not surprising. It was trans-formative. Although I haven’t had much track time to fine tune, with the help of Patrick (and some dumb luck?) the initial results have exceeded my expectations.
’08 CR
Ohlins TTX/12k, 10k/all the bits and pieces/double adj. /Lowered about 1”
Hoosier 235/620x17 on CE28x9’s
Carbotech pads-10’s and 8’s
Adj front sway at 566#
-3 camber /0 toe; -3 camber/1/16 total toe in-rear
Installation was straightforward. After having the car corner balanced and aligned, I found it negotiated crappy Ohio roads much more comfortably than stock. Starting the adjusters both mid range, at Mid Ohio, lap times were reduced 4% out of the box and the car was very steerable with the throttle. Before an electrical issue at Daytona, I saw 144 in practice and the car was completely controllable in the tri-oval. Not using all the travel, yet, so looking to soften the settings this spring. Shoulda done this a long time ago. Still one of, if not the biggest bang for the buck…with a big tip of the hat to Patrick at Urge who is always incredibly responsive, responsible, and interested.
’08 CR
integfoo
06-06-2015 06:15 PM
02_s2k
04-22-2013 03:48 AM
