Programming NEW ECU to keys
Old 05-07-2012, 07:27 PM
Pinky's Avatar
Default Programming NEW ECU to keys
I am swapping back to my original '00 ECU and after well a few years of heat/cold and being out of the car it's forgotten it's programming.(think of it as a blank slate)
What are my options now? Mugen ECU is going bye bye as of tomorrow I think but I can't drive the car to Honda to get it programmed.
I read that there is a way to temporarily bypass the immobilizer but still not crazy about paying the dealership to re-program the car.....though might be my only option.
Thoughts or options?
Old 05-08-2012, 02:13 AM
boltonblue's Avatar
Received 3,520 Likes on 2,381 Posts
Sometimes you have to break down and pat "The Man".
You could drive it to the dealer and swap ecu's there.
Old 05-08-2012, 05:38 AM
Pinky's Avatar
I am in no real rush as the engine well it needs replacing so I am not driving it this summer. Even if I get the bypass code for the immobilizer from the dealer just to move it around in the garage that will be fine. If I gotta PAY THE MAN I will do that but no reason to do it right this second if that is my only choice.
Hoping that there are other options.
Old 05-08-2012, 06:42 AM
daktruckie99's Avatar
This guy from Metro can do it. He's got some good reviews too.
https://www.s2ki.com/s2000/topic/909...-need-repairs/
-Mike
Old 05-08-2012, 12:25 PM
drhess06259's Avatar
hondata by=passes it also idk what your end goal is.
also you can get another ecu and they key and use your key in the ignition with the other key held next to it and it starts once started you don't need to keep it there
Old 05-08-2012, 03:53 PM
boltonblue's Avatar
hey Pinky what's da scoop on the motor?
was your ticking more than valves?
Old 05-08-2012, 04:46 PM
Pinky's Avatar
Ok so after 24 hours the ECU smartened up and recognizes the KEY NOW. Go figure. Well saves me a whole bunch of headache!
Blue: Yeah it was more than valves! 99% sure it's a spun bearing! I think that it's #3 or #4 based on where the noise is coming up the intake runners. YouTube is an amazing tool. I found 3-4 other cars with the same exact sound one of them was off S2KI that said that the result was a spun bearing. Which now makes sense in that it gets louder under throttle and quieter almost gone on deceleration when there is no load on the piston. Saving up to do a new short block and see Mr. Ballistic. Probably will do a new water pump while we are at it seeing as it's got 100K on it. Your already there!
DutchyFutch
10-11-2014 11:40 AM
R1_Pilot
01-08-2010 11:53 AM
killasystems
02-01-2008 05:56 AM
dmw16
03-16-2007 06:27 AM
jimbo69ny
07-10-2003 08:53 PM
Quick Reply: Programming NEW ECU to keys
