Alabama S2000 Owners Club Areas including Huntsville, Birmingham, Florence, Decatur, Anniston, and Tuscaloosa
Who would you recommend to install 4:57s in Bham?
Old 01-08-2005, 01:24 PM
babyray's Avatar
Default Who would you recommend to install 4:57s in Bham?
Don't want to tackle this myself. Haven't purchased them yet but I am seriously considering. Thanks.
Old 01-08-2005, 02:16 PM
Slows2k's Avatar
I know a Honda technician in Montgomery who can do it. (me) It's not going to be an overnight swap though. Swapping gears out of the diff takes quite some time.
Old 01-08-2005, 02:34 PM
CDjunkie's Avatar
Received 1,292 Likes on 1,044 Posts
That would have been my recomendation.
Old 01-10-2005, 07:10 AM
RBC3's Avatar
Yeah, Slow is the man to see. Plus, Montgomery is only an hour away!!
Old 01-10-2005, 07:28 AM
babyray's Avatar
Thanks everyone.
Slow,
How long is quite some time?
Old 01-10-2005, 03:18 PM
Slows2k's Avatar
The differentials are very time consuming to set-up, involving multiple mock-up assemblies to check the clearances. You also have to use a new crush sleeve and pinion seal everytime you check the pinion depth. The last diff I rebuilt took 3 pinion seals and crush washers to set correctly. I also reccomend replacing axles seals, both carrier and pinion bearings at the same time. The bearings and seals run around $300, plus the labor to assemble. I've been charging $300 for assembly.
I have to build them in my spare time, which is running a little thin.
If you bring be a diff, the turn-around could be as little as a week, maybe 2 weeks if additional pinion shims need to be ordered.
suzuka-blue-s2k
02-04-2011 11:51 AM
suprmonky73
07-29-2009 12:50 PM
kinetica
01-05-2007 01:50 AM
Silver S2k4
11-24-2006 07:37 AM
Dolemike
09-28-2006 08:44 PM
Quick Reply: Who would you recommend to install 4:57s in Bham?
