Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Single best mod
Old Jul 22, 2010 | 10:48 PM
  #21
watchdogd's Avatar
Not familiar with Electric exhaust cut out. Please explain
Old Jul 22, 2010 | 11:21 PM
  #22
3en's Avatar
3en
Heres one I pulled off google.
http://www.jegs.com/i/Dougs-Headers/776/DE...oductId=1282659
You basically weld it off of your stock exhaust so it stays quiet while cruising then when you romp on it, it opens up either by air pressure like a wastegate, or an electric actuator depending on the type of cutout you get. The idea is to allow more air flow and reduce pressure under high rpm in WOT.
How well it works on an N/A application? I dunno. But it would be interesting to see.
Old Jul 23, 2010 | 08:01 AM
  #23
ZeroF's Avatar
Mugen Hardtop for Go Tuning.
Proven gains across the power band.
Old Jul 23, 2010 | 11:39 AM
  #24
UMS Tuning's Avatar
Originally Posted by 4DCurvs,Jul 22 2010, 04:53 PM
The single best bang-for-the-buck mod is an HPDE track day
I would drive the car to the limit and see if you even need to mod it to begin with.
I like this one! Track Days for the win!
Honestly........
I would say FlashPro for you sir.......
I have seen a 100% stock car make 220 to the ground with tuning alone....overall drivability is better and car is just more fun in general.
Peak gains in the neighborhood of10-15 whp and midrange gains of almost 20 ft lbs of torque
Flash Pro and tune would be about $1000.....
BTW...I dyno tested the 70mm Invidia Test Pipe.....made a 1hp improvement....maybe. THe best thing the TP did was eliminate the drone associated with aftermarket exhausts
Old Jul 24, 2010 | 06:10 AM
  #25
watchdogd's Avatar
Sounds like Flash Pro FTW! Can the car be flashed back to stock ?
Old Jul 24, 2010 | 07:49 PM
  #26
CypherAZ's Avatar
Originally Posted by 9k All The WAY,Jul 22 2010, 01:52 PM
You'll go thru the gears faster but not be faster with speed. You'll go thru the power band too quick and with the stock gears your in it longer.
um yeah no.....
[media]http://www.youtube.com/watch?v=89rGbTbFfKs [/media]
Old Jul 26, 2010 | 10:48 AM
  #27
UMS Tuning's Avatar
Yes.... to Hondata's "stock" MAP
Old Jul 26, 2010 | 01:45 PM
  #28
Boofster's Avatar
I can vouch for the tuning. You'll get a massive mid-range boost.
If you can drop a grand, do it. Plus if you get FI later, you can re-use it.
jeremeep
Nov 16, 2013 09:15 AM
zippity
13
Oct 24, 2011 09:46 AM
zwhiteman08
Jan 27, 2011 11:15 PM
BumbleBee01
May 28, 2010 03:39 PM
zerospel
Dec 16, 2006 01:00 AM
