Ark-La-Tex S2000 Owners Covering Arkansas, Louisiana, and East Texas
Maint. req.
Old Apr 12, 2010 | 10:02 PM
AndrewShaffer's Avatar
Default Maint. req.
Ya so my maint. req. light came on this weekend so i went to auto zone to get the code read well nothing was read so any ideas whats going on?
Old Apr 12, 2010 | 10:30 PM
ans2k's Avatar
oil...... usually the case
ans2k's Avatar
how many miles is on that s?
Old Apr 13, 2010 | 04:00 AM
icemans2k02's Avatar
Its nothing to threat about. Its just to remind you to do maintenance. They could have changed the oil 50 miles ago and not reset it therefore it will pop up. Just reset it and you are good sir.
Old Apr 13, 2010 | 05:45 AM
JulieU's Avatar
Administrator
The maintenance indicator light (MIL) is not the same as a check engine light (CEL). They're two totally separate things. The MIL is simply a reminder like Bobby said.
Old Apr 13, 2010 | 05:54 AM
Munnerlyn's Avatar
The process to reset will be located in the owners manual for reference.
Old Apr 13, 2010 | 07:47 AM
Ch0pper's Avatar
If I'm not mistaken it will come on every 7,500 miles or so.
The manual will tell you how to reset.... usually consists of holding down the trip reset button and something else.
If it tells you to remove your clothes and stand on your head, you are reading the wrong manual.
Old Apr 13, 2010 | 08:28 AM
press and hold sel/res and the mph/kph toggle..so basically both those buttons. while doing so turn the key to the on position basically all the way over like you are about to start it but dont then keep holding buttons for 10 seconds, should beep then go off.
Old Apr 13, 2010 | 11:10 AM
Sweet thanks for the tips..I know it doesn't need a oil change i just did it last Thursday..Ill try resetting it..
travanx
Oct 24, 2011 07:04 PM
ebeldesign
Sep 16, 2005 02:18 PM
VaBeachEd
May 13, 2005 12:00 PM
Rez311
Oct 19, 2004 10:25 AM
jss2k
Dec 19, 2002 11:29 AM
