Australia & New Zealand S2000 Owners Members from the land downunder.
99 S2K doesn't have OBDII, How can you read CEL?
Old 05-17-2014, 05:37 PM
nazzri's Avatar
Default 99 S2K doesn't have OBDII, How can you read CEL?
Hey guys, i was told that the 99 Australian s2000's dont have the OBDII connector? How can it be read?
thanks
Old 05-18-2014, 01:59 AM
ryanswhites2k's Avatar
From everything I've read you can't use a obd2 scanner. Although surely there must be a adaptor cable that reads the faults, I mean what do the dealerships do in there workshops
Old 05-18-2014, 03:53 AM
Seanix's Avatar
Look for the DLC under the drive side dash. There should be 2 blue plugs held in side a green plug case.
Find the blue plug with 2 wires and use a paper clip to jump the terminals.
Turn ignition on but don't start the car.
The engine check light will flash and display any stored codes.
Hope that helps.
Old 05-18-2014, 05:55 PM
AusS2000's Avatar
Dealerships use a PGM-FI reader. This was Honda's standard before OBDII was introduced.
Old 05-18-2014, 05:58 PM
pure_na's Avatar
Hope that helps.
afaik, there is no reason to spend your money on anything as this works perfectly fine.
Old 06-03-2014, 08:11 PM
miloking's Avatar
Had same issue with my NZ new S2000 (UKDM) so no obd2....
My first JDM s2000 had OBD2 and loved the amount of info you could get so I bought one of these localy (trademe ftw!) ($150 so about 130 AUSD)....
as you can see apart from error codes from ECU,SRS,ABS etc it shows all sorts of useful data...
which paper clip in a plug and cluster wont with blinking lights
also you can do things like reset steering angle sensor with it like dealer with PGM tester...
chrisesteban
01-09-2007 08:48 AM
volcomrider6
02-17-2006 04:37 PM
b18c195
12-30-2005 10:58 AM
ggarriso
07-30-2005 05:24 PM
Quick Reply: 99 S2K doesn't have OBDII, How can you read CEL?
