apexi AFC/vtec problems
Old Apr 6, 2009 | 06:42 PM
eric_reed_ii's Avatar
Angry apexi AFC/vtec problems
I recently bought an apexi vtec/air fuel controller. The guy that hooked it up for me had it on his car and it worked. But when we hooked it up on my s it won't read the vtec or contol it or the air fuel! It only reads the rpms and the throttle %! Any suggestions?
Old Apr 6, 2009 | 06:45 PM
Just 4 ur knowledge... I know very little about the electronics on this car, let alone the ecu. He had the controller on a 240 sx that was turboed
Thanks,
Eric
Old Apr 6, 2009 | 07:23 PM
YELLOW JACKET's Avatar
Is your controller hard wired or plug-n-play? i have one on my S and it works just fine. your best bet is to take it to someone with a dyno and experience with the apexi. if you want to get it right, do that. if your is hard wired, you may not have it wired right. good luck with it.
Old Apr 6, 2009 | 07:40 PM
S2000Shifter's Avatar
Is it a VAFC or an SAFC? If it's an SAFC it won't work. VAFC (Vtec Air/Fuel Controller) works on Honda's and Acura's only...
Old Apr 7, 2009 | 05:06 AM
Its a vafc. He only used it on his 240 as a y ban air fuel meter
Old Apr 7, 2009 | 06:31 AM
DougEFresh's Avatar
my guess is u might want to double check the vtec and a/f wires to make sure they are in the right locations on the ecu. pretty simple fix i bet.
Old Apr 7, 2009 | 07:24 AM
I talked 2 the guy with the 240 today. He said that when he put it in my car his wiring diagram didn't show the vtec wire from the ecu on the f series motor. So all he could hook up was the rpms. Is there a wiring diagram that u guys know of 4 this so I could do it maybe this weekend?
Old Apr 7, 2009 | 10:17 AM
DougEFresh's Avatar
contact Apex they should be able to help u out. when i get home ill get the vtec wire pin out from the ecu for ya.
-Doug
Old Apr 7, 2009 | 12:38 PM
thanks man
Eric
Old Apr 7, 2009 | 01:54 PM
If you have no luck, pm me and i can look it up in the manual as to what pin it is.
wang_uk
Oct 21, 2005 06:06 AM
WayneTeK
Mar 14, 2005 01:00 PM
elude
Dec 29, 2004 05:11 AM
dayves2k
Nov 24, 2003 11:32 AM
richiesanto
Aug 3, 2003 01:14 AM
