Hawaii S2000 Owners S2000 Owners in Paradise Hawaii Owners
Installation Help?
Old Apr 13, 2007 | 03:19 PM
SIIK03's Avatar
Thumbs up Installation Help?
Just wanted to ask if anyone was up for letting me use some tools and help install my coilovers when they get in. Or just let me use some tools. Also ordered the half shaft spacers and wanted to install those too, they are the T1R ones so all i need to do is loosen the half shafts to install them. Well any help would be great. Thanks.
Carlos
Old Apr 13, 2007 | 03:38 PM
mackeywatson's Avatar
You don't need many tools for the coilovers. 10mm, 14mm (deep), and 17mm socket, and a ratchet, and extension, and another 17mm wrench to hold the bolt while you tighten the nut. I think it's 17mm....could be 19mm. It would help to have another person cuz you'll probably have to push up or down on the rotors to get it to line up. Unfortunately I won't be able to physically help you because I am really busy with school.
Old Apr 13, 2007 | 05:07 PM
SIIK03's Avatar
Thanks mackeywatson
Old Apr 13, 2007 | 09:42 PM
SIIK03's Avatar
Old Apr 13, 2007 | 11:27 PM
avallach's Avatar
Well, I've never installed coilovers on a S2K, but I'll help you if you get desperate enough. I've got the tools and a house with a garage.
I would like to get some practice on yours, so perhaps, I can do mine at a later date.
You know, the car's already low in stock form. My jack barely fits underneath the car. How low are you planning to go?
I'm an option if you need it. Cheers.
WTF are "half-shaft" spacers? What's it for? This should tell you what you're in for.
Old Apr 13, 2007 | 11:56 PM
SIIK03's Avatar
avallach thanks for the offer, probably will take you up on it too. Ive installed coilovers before on my prelude, just not on my s2k, so it shouldnt be too different. the half-shaft spacers are for when you lower the car, think only ap1, it corrects the angle of how the drive shafts, or half-shafts, align in the differential as far as i know. someone correct me if im wrong. It all should be in next week sometime, think latest was around tuesday. So whenever you are willing or have time, I can adjust my busy schedule, said that extremely sarcasticly. Also Im not planning on slamming it, just want it probably around .5" to 1" above the tire for now because I dont know if my rear tires will rub.
Old Apr 14, 2007 | 12:04 AM
Installing the coilovers are pretty easy. I've done it a few times. The hardest part will be accessing the driver's rear top strut nuts. The gas line is in the way, so you need the extension, and you'll have to push the accordian looking thing hard to the side. A 6in extension will work perfectly.
Old Apr 14, 2007 | 12:25 AM
avallach's Avatar
It's gotta be on a weekend. Cool, I've taken apart my 5th Gen Prelude about a 1/2 dozen times, too. There's a wirite-up here. I'll be studying it a bit.
I'll PM you my cell later... I need to sleep. Long, Long week.
Old Apr 14, 2007 | 03:57 AM
S2JK's Avatar
i just installed my coilover set. wasnt too hard, just need someone to stop on the rotors to get the bolt out.
if you need help just give me a call, 203-4078.
J-rod
May 20, 2009 04:26 PM
MDS2KAp1
Feb 8, 2007 05:29 PM
robrob
Jan 5, 2007 08:40 AM
xdavieexx
Oct 14, 2006 05:48 PM
9krevz01
Mar 16, 2004 11:24 PM
