Lucid rear speakers
Old Mar 18, 2003 | 05:58 PM
Jim Sutherland's Avatar
Default Lucid rear speakers
I installed Lucid's rear speakers this week end. I have no experience with installing HU or speakers. I got 5.25 Kenwood. The install was as easy as I could have hoped. The HU came out with no problem. I had trouble with the carpet clips. I tried to find the clip remover, but could not. The removal of the rear panels not a problem, I suggest the use of a socket and not the screwdriver. The best part is that the sound is 100% better. It was well worth the money. If I can do the project, anyone can.
Old Mar 18, 2003 | 07:11 PM
fmah's Avatar
Here's how to make a carpet clip remover. Go to your kitchen utensil drawer. Get a fork. Shorten the tines by cutting or grinding them. Spread the inside tines apart so that the fork looks more like a "Y" than Bart Simpson's hairdo (''''). Make sure that you smooth/polish your work so that you don't leave scratches on your upholstery or plastic trim. You can slip the modified fork under the clip and use the slight curve of the fork to lever the clip out. Works on many clips, but especially well on carpet.
Old Mar 18, 2003 | 08:30 PM
walkabt's Avatar
Or you can buy one for $3.95 like I did and save your fork
Old Mar 18, 2003 | 08:35 PM
I tried G. I. Joes, Napa and AutoZone. they did not have the tool.
Old Mar 18, 2003 | 11:39 PM
lucid's Avatar
Jim, thanks for the positive feedback, I appreciate it.
Would you said its worth it to ADD the clip remover to rear packages? Aprox cost ~ 5-10 addl. and OR add color matched clips 1 or 2 to it. This of course would be an option.
Old Mar 19, 2003 | 05:08 AM
PJK3's Avatar
sigh. i should have bought the clip remover. those blasted little clips/plugs are a pain to get out... and even using a adapted clip remover i'm going to have to replace a few... the buggers are a bit expensive too at around $2 a pop.
(of course, i wasn't adding rear speakers, but was running wire along the console... still, i'm fairly sure it was the same clips.)
Old Mar 19, 2003 | 05:39 AM
TepEvan's Avatar
I bought a "trim puller" for about $7 from Salvo auto parts, so you might try using that name or checking around some more.
lucid- I think you should offer it as a separate item, since some people already have an item in their toolkit that they use (or kitchen drawer ). good review though!
Old Mar 19, 2003 | 04:07 PM
Lucid.
I do not think you need to add clips. If they are broken, just go to the Honda dealer. They are $2.09. As to the tool, you may want that to be a option. I would have liked a photo of the tool and see the best way to place it. It hard to write instructions for someone, like me, who does not know what they are doing. Again, I think you did a great job with the product and instruction. If I can install the speakers, anyone can. More important, the speakers are a huge improvement in the sound system. I agree with all those who have said that is is the best mod. Thanks.
zeroptzero
Nov 29, 2009 08:22 PM
pdexta
Dec 1, 2005 03:59 AM
SilverstoneS2k_FL
Mar 15, 2005 10:30 AM
jcoates1
Feb 7, 2002 02:08 PM
