Should the engine block # match your VIN.
Old Jun 30, 2002 | 04:15 AM
ItalianBucwheat's Avatar
Default Should the engine block # match your VIN.
Ok people! I was staring at my engine. Took a close look at my engine block number. The question is, are the last four digits of the block # suppose to match the last four digits of the vin #. Mine does not It is close but the last number is different. Did Honda make a factory error? Just curious!
Old Jun 30, 2002 | 07:30 AM
Hondafan's Avatar
Did you buy your car used? The numbers should all match: engine, trans, fenders, hood etc.
Old Jun 30, 2002 | 08:13 AM
Brand new. 60 miles on it when bought. All the vins match on the car. But the stamped vin on the engine block the "f20*******" number stamped on the block is differnet. For examle if my last four vin numbers where 1234 stamped in metal on the block it is
f20*****1238. The last digit is slightly of. These are not my real vin numbers but for example purpose only.
Old Jun 30, 2002 | 08:45 AM
mav's Avatar
mav
Hmmmm... All the VIN's should match. And why so many, 60 miles , on a new S2000?
Old Jun 30, 2002 | 09:10 AM
60 miles...well i am sure it had a few test drives. Around here unless you order or find it right off the truck they have some miles on them. I had a choice of silver, blue, red at one dealer all had over 40 miles on them. I wanted black only two in the state both had about 60 miles on them. i am not super anal and sixty miles was ok with me. But please someone go outside or in the garage and check the block stamp to see if the last four digits are the same as the last four on your vin!
Old Jun 30, 2002 | 09:17 AM
morpheus's Avatar
All should match, if the block number is higher than the vin, it may be a situation where honda replaced the engine for one reason or another. I doubt it takes any value from the car as long as you have the paperwork to show it was purchased new at a honda dealer. I'm no expert, this is just the first thought that came to mind when I read the post.
Old Jun 30, 2002 | 09:24 AM
ultimate lurker's Avatar
I don't know, my 2000 doesn't match (the engine number being a couple numbers higher). I've seen several others that are the same way.
UL
[QUOTE]Originally posted by morpheus
[B]All should match, if the block number is higher than the vin, it may be a situation where honda replaced the engine for one reason or another.
Old Jun 30, 2002 | 10:14 AM
S2000 Owner's Avatar
Sorry Guys
engine numbers DO NOT MATCH vin number They are close but not matching!!
Old Jun 30, 2002 | 12:16 PM
Ahhhh good deal ...yet again another of my questions answered in the same day. Thankyou all ....especially "s2000 owner" and "ulitamate lurker". I would be a babe in the woods with out this web site!
plizzat
May 1, 2017 03:25 PM
traxtar614
Jul 16, 2011 11:02 PM
cooker101
Nov 30, 2008 11:31 AM
shakes
Jan 24, 2007 09:57 AM
apex2k
Jan 9, 2005 07:32 PM
