AC settings on 1052u
Old Nov 19, 2009 | 09:12 AM
CaseyGW's Avatar
Default AC settings on 1052u
bought my 1052u used and i believe someone previously had messed with the ac settings and just wanted to check what the default settings are? thanks!
Old Nov 19, 2009 | 09:20 AM
300sx's Avatar
"Default" or what's in the 1052 base map...
Here's my settings...
Old Nov 19, 2009 | 09:29 AM
CaseyGW's Avatar
thanks robbie. what did the changes you make do for you
Old Nov 19, 2009 | 09:52 AM
300sx's Avatar
Well I delayed the compressor to give the iacv a chance to do something so the idle wouldn't dip and adding to the load comp helped that as well. Still wasn't perfect though because instead of a dip in rpms I'd get a slight rev. That's just where I gave up at I think lol.
Just play with those two numbers to get it how you like it best, obviously having the fan on and using the a/c button to test the settings.
Way too cold around here to be worrying about a/c
Old Nov 19, 2009 | 10:29 AM
CaseyGW's Avatar
only reason im even asking is for my defrost hahaha. and my does dip a bit so ill give the delay and comp a little bit of playing. thanks!
Old Nov 19, 2009 | 10:52 AM
300sx's Avatar
No problem man
And don't know if you know this or not but you can program your a/c to where you can turn it off with the defrost on...
Old Nov 19, 2009 | 11:14 AM
CaseyGW's Avatar
i may have read that somewhere...is it where you hold certain buttons on the climate control? horrible memory
Old Nov 19, 2009 | 01:29 PM
300sx's Avatar
Key off, turn knobs to the left, hold both a/c and recirc buttons, key on and keep holding until the a/c light stops blinking.
Charper732
Feb 13, 2017 08:54 AM
chef-j
Jun 19, 2010 01:24 AM
Gernby
Apr 22, 2010 01:02 PM
datchineseguy
May 17, 2008 09:05 PM
ChrisWells
Nov 23, 2003 01:11 PM
