AC settings on 1052u
bought my 1052u used and i believe someone previously had messed with the ac settings and just wanted to check what the default settings are? thanks!
Well I delayed the compressor to give the iacv a chance to do something so the idle wouldn't dip and adding to the load comp helped that as well. Still wasn't perfect though because instead of a dip in rpms I'd get a slight rev. That's just where I gave up at I think lol.
Just play with those two numbers to get it how you like it best, obviously having the fan on and using the a/c button to test the settings.
Way too cold around here to be worrying about a/c
Gernby
Apr 22, 2010 01:02 PM
