F24 Build
Originally Posted by ksrd,Apr 9 2008, 12:10 PM
Keep up the good.. I'm patiently waiting for some results.
I finally got a pic of what the K24 crank looks like.. I see what you meant about the lip on the crank..
By all means... I don't mind at all... afterall this forum is all about sharing and helping others.. I'm just doing my part. It's least I can do after learning so much from your build. You've inspired me to do my own build as well.. I actually gathered most of the parts. Wish me luck...
My oem cams are back in but since it's late, I'm going to wait til tomorrow to set the lash and button it up. Then I'll find out if it's the cams. One note though, I found a video on K20A.org showing the chain slap caused by cams, like mine, so prior to pulling the S2 cams I turned the engine over a couple times to watch for tensioner movement. And there was a lot of tensioner movement or in other words, the tensioner would have a lot of slack to eat up at certain points. This is much more pronounced than when I turned it over with the stock cams. More to come.
Back to question about the EMS... Will the Greddy Ulitmate do the job? What about the basic E-Manage... Cause I have one on hand... .. Would that be good enough for such a build? I'm still debating about AEM or Ultimate. I already have a K-Pro for my K20.. So. I want to try something different. I'm leaning towards Ultimate for the price, but not going to cheap out if it won't do the job.
Piggybacks are piggybacks AFC's, FIC's, Emanage, Emanage ultimate etc will only allow you to pull/add fuel and only pull timing. Also the tune is only effective at open loop. Most of your daily driving is in closed loop. Piggybacks don't work well when you change values in closed loop. Common issues are poor startup, poor idle, car jerks at a given rpm, horrible gas mileage etc.
