F24 Build
They do make overbore pistons but if you are going to resleeve with aftermarket sleeves, then you will be able to run pretty much any aftermarket piston instead of limiting yourself to frp friendly pistons.
Ah makes perfect sense. Sorry didn't know what I was thinking.
Also Im just curious, did you ever have your car dynoed on that same dyno before the stroker? I know some dynapacks (cough churchs cough) read quite high. I'm just curious what your gains are over the delta.
I'm leaning toward a Tracy Sports header. I wonder if Kraftwerks will produce something like this for an F20:
http://www.ojengineering.com/graphics/prod...ium_header1.jpg
http://www.ojengineering.com/graphics/prod...ader_alt_sq.jpg
http://www.ojengineering.com/graphic...header2_sm.jpg
Hey Kial on the bottom end of the block was there any special brackets or anythign that you had to fab.... The only reason I ask is that GE said for them to resleeve and set up for the build then they need a few months to train there new engine builder on how it was done by the last one. And they said there was alot of fab work on the bottom end
There was nothing to fab but I didn't resleeve. I have never had a blocked sleeved but I don't there is any fab work required. You may want to find out exactly what they are going to fab.
