F24 Build
Old Jan 21, 2009 | 03:26 PM
  #391
ABCVTEC's Avatar
bump for updates, discussion, etc. hah
Old Feb 5, 2009 | 06:32 AM
  #392
kial007's Avatar
If you wanted to machine the piston skirts to use mahle pistons, I'm sure you could.
Old Mar 17, 2009 | 02:45 PM
  #393
chris_barry's Avatar
I was able to fit the bore squirters with Mahle gold pistons. I had to bend the squirter tubes inwards to clear the web of the piston, and also upwards away from the piston. I then notched the skirt so there was plenty of room ( 3mm) clearance.
Old Mar 17, 2009 | 03:34 PM
  #394
INTJ's Avatar
Originally Posted by N2oExpresS2k,Oct 7 2008, 06:49 AM
tracked s2k's run their oil temps up to 260 degrees. That's why oil squirters are so important. If you plan to run your car like that an oil cooler will keep everything safe. Oil squirters are more variable in your motor. Endyn doesn't use them in any built motors.
I'm with zob. The squirters were designed after failures. This gets oil under the piston to cool it and it helps with lubrication. There is less mass in the s2k piston and it has less skirt material to transfer heat out. The oil is the fastest means to keep it cool, 7:1 or something in terms of heat transfer over air.
An oil cooler is far more prone to failure over a fixed squirter if you are going down that road. But they really do different things, cooler (actually a more stable oil temp/lower peak) oil won't help the piston, it just keeps the oil in its performance range.
FYI, the S2000 has a factory oil cooler...http://corporate.honda.com/press/art...=2003100141147
Freeway driving, no matter how aggressive, is the lowest load on the engine. If you get a failure there some was horribly wrong.
Old Mar 18, 2009 | 07:48 AM
  #395
spectacle's Avatar
Where do you see info about a oil cooler?
Old Mar 18, 2009 | 08:57 AM
  #396
tantheman's Avatar
Impressive build!
Tan
Old May 10, 2009 | 10:53 PM
  #397
Ezekiel55's Avatar
Wow Nice work
Old Aug 12, 2009 | 10:07 AM
  #398
wadzii's Avatar
Banned
bringing this back from the dead.. kinda
it's a bad idea to use mahle h22 pistons, they have the pins offset to reduce noise and wear on the piston/cylinder wall. this offset is opposite of what you would need for the f20c due to the fact that the engine rotate opposite directions.
this could be why the motor makes so much noise. Wiseco and the facotry pistons have an offset pin. i'm not sure cp's or je's do or not
Old Aug 15, 2009 | 01:31 PM
  #399
siik_ap2's Avatar
u can flip the pistons and just cut the reliefs on the exhaust side of the piston to make up for the bigger intake valve and solve the offset issue, assuming they have the same exact offset keeping in mind the motors spin different directions..
Old Aug 30, 2009 | 09:14 AM
  #400
stooky2's Avatar
do you know or can anyone calculate if i were to use the 9.0 to 1 mahle pistons would i still net that 9.0 to 1 compression ratio or would it be more or less ?
