F24 Build
Old Aug 30, 2009 | 09:25 AM
  #401
wadzii's Avatar
Banned
Originally Posted by oober,Aug 15 2009, 09:31 PM
u can flip the pistons and just cut the reliefs on the exhaust side of the piston to make up for the bigger intake valve and solve the offset issue, assuming they have the same exact offset keeping in mind the motors spin different directions..
or just buy the right pistons
Old Aug 31, 2009 | 12:10 PM
  #402
cyde01's Avatar
what exactly are the "right" pistons? most aftermarket pistons are not FRM friendly and require sleeving the cylinders, which is $$$. the reason why people use the mahle gold series H22 pistons is because they are FRM friendly and do not require sleeving. is there an aftermarket piston u can use with the k24 crank that is FRM friendly and has the right offset?
Old Aug 31, 2009 | 03:33 PM
  #403
siik_ap2's Avatar
a.k.a custom..
Old Aug 31, 2009 | 04:08 PM
  #404
wadzii's Avatar
Banned
mahle makes custom pistons for about $100 more than shelf pistons.
if you want contact info for an engineer at mahle that can do this for you pm me.
fyi, i did the original testing on the h22 gold series pistons.
if there is demand i can talk to them about a shelf "custom" piston for this application.
Old Sep 1, 2009 | 10:07 AM
  #405
cyde01's Avatar
WOAH!!!! GOOD TO KNOW!!!!
Old Sep 2, 2009 | 01:08 PM
  #406
vehicular's Avatar
Does anyone know where to find info on whether the Accord cranks have the same counterweight structure/ masses as the TSX crank? If I'm going to go to the trouble to build a short block, I'm going to use a set of Eagle or Belfab rods and turn the 9000 rpm that the dyno plots show the motor wanting to turn.
Kial, how much do you beat on your motor? How often do you see redline? How high is your rev limiter? I'm really interested in building one of these for my street car, but I'm curious as to how quickly I'll destroy it...
Old Sep 2, 2009 | 02:32 PM
  #407
wadzii's Avatar
Banned
tsx cranks are different, if i remember right they have wider rod journals.
but afaik either one has proven reliable in k24/k20 setups
Old Sep 9, 2009 | 08:43 AM
  #408
wadzii's Avatar
Banned
I did some math on the 2.4 stroker and here's what i have come up with, if the guys at mahle are willing to do something i think this would be the best option.
k24, 99mm crank
use stock f22c rod
the piston would have a shorter compression height and a 7cc dome
this would make the engine much happier geometrically speaking and give you around 12.5:1 compression which depending on cam choice will work with pump gas.
the only issue i can think of is the stock size f22c pin may be too big to be moved up to a .978" compression height.
to use an h22 rod, the required compression height would be 1.24 inches, which would make the piston unstable at high rpms.
Old Sep 9, 2009 | 11:23 AM
  #409
cyde01's Avatar
12.5:1 with pump gas!!? stupid economy!! if i had the $$ i wud so do this. how big could you go over bore?
Old Sep 9, 2009 | 11:56 AM
  #410
wadzii's Avatar
Banned
I wouldnt overbore at all.
12.5:1 would only work with bigger cams, on stock cams i wouldnt go much more than 11.5:1
