NA: ITB's
Old Aug 8, 2007 | 07:38 PM
  #221
Antonov's Avatar
cant wait to see you're dyno alejo, i was wondering if you could weigh the items you removed, heatercore, a/c, stock mani and what not, if not too much trouble of coarse. Thanx
Old Aug 8, 2007 | 09:03 PM
  #222
Mr. Francesco's Avatar
Originally Posted by alejo,Aug 8 2007, 08:42 PM
no, I'm talking about the whole system. Call Jimmy at Fuji Racing.
oh, so your ITB body was built to accept the sensor?
Old Aug 9, 2007 | 01:27 AM
  #223
smirfs2k05's Avatar
Originally Posted by alejo,Aug 8 2007, 12:45 PM
I'll be glad to give you mine (AP2) but it's at your own risk.
By the way, I know it's been said here before but going back to stock from this would be a very major project.
Why do you say that? What all is needed tobe modified?
Old Aug 9, 2007 | 02:49 AM
  #224
APEXSEAL's Avatar
Originally Posted by Francesco,Aug 8 2007, 04:28 PM
did your tuner create a base map, or did they modify a pre existing one?
when i was talking to my tuner, he told me that we would have to focus on alot of low end and idle tuning so that the car would idle correctly and start right up because of the loss of the idle air control valve.
an idle air control valve can be easily incorporated to the vacuum chamber.
Old Aug 9, 2007 | 06:25 AM
  #225
alejo's Avatar
Yes
Old Aug 9, 2007 | 06:26 AM
  #226
alejo's Avatar
I kept the AC - my fat arse needs air until I can trailer the car.
I will take pics this weekend and put up a proper post.
Old Aug 9, 2007 | 08:22 AM
  #227
Originally Posted by alejo,Aug 9 2007, 09:25 AM
Yes
now is this a physical piece that attaches to the ITB unit, or is it more like a tap where the temp sensor can hook up to on the body?
on another note, i remember my tuner was telling me that if I wanted to we could actually tap the IACV into the body of the ITB's so that I can keep that sensor for cold starts. He said it would be alot of work though and just using proper tuning would allow us to avoid this.
Old Aug 9, 2007 | 08:25 AM
  #228
alejo's Avatar
In mine it's just a tap on the ITB manifold, it is exactly where the stock sensor position is located.
Old Aug 9, 2007 | 10:25 AM
  #229
gotcha. thanks for all the info.
care to inform me on the difference between air horn lenghts? 50mm vs. 80mm? pros/cons.
Old Aug 9, 2007 | 10:29 AM
  #230
alejo's Avatar
I don't really know - I just bought what several sources said was a good fit for the car. All I wanted was to relieve weight up front and have a little more punch - both well accomplished.
