NA: ITB's
Old Aug 9, 2007 | 10:30 AM
  #231
Mr. Francesco's Avatar
Originally Posted by alejo,Aug 9 2007, 01:29 PM
I don't really know - I just bought what several sources said was a good fit for the car. All I wanted was to relieve weight up front and have a little more punch - both well accomplished.
im sure that was achieved.
how much does the oem intake mani weigh? the ITB's can't be more than 20lbs.
Old Aug 9, 2007 | 10:39 AM
  #232
alejo's Avatar
ITB's are more like 7 pounds, if that. I'm going to weigh all the junk I removed, if I had to guess I removed about 50 pounds - pretty crazy to remove so much weight of excellent Honda engineering and replace it with only a fraction of aftermarket goodness.
Old Aug 9, 2007 | 11:07 AM
  #233
i agree, but look at all the other weight you save if you like me. i can't wait to remove my soft top.
Old Aug 9, 2007 | 11:56 AM
  #234
alejo's Avatar
My soft-top, carpets, sound deadening an other goodies are long gone
Old Aug 9, 2007 | 12:14 PM
  #235
FormulaRedline's Avatar
Alejo, did you do anything about filtration?
Old Aug 9, 2007 | 01:07 PM
  #236
alejo's Avatar
not really - I installed an aircraft grade cooling hose to bring outside air to the vicinity of the intakes and put a mesh on the entry of the hose - it's not getting any ram air though as it is using the wheel-well entry to the engine compartment.
Old Aug 9, 2007 | 06:21 PM
  #237
i plan to have a mugen intake in my car to direct the air to the itb's. im not sure if ill use filters though, i hear they restrict power.
Old Aug 9, 2007 | 07:59 PM
  #238
circa86's Avatar
wonderful idea, I hear it works wonders
Old Aug 9, 2007 | 08:27 PM
  #239
circa86's Avatar
haha use the AC to cool the intake area of the engine bay
that makes lots of sense doesn't it
the more power you take away the more you add! that totally makes sense!
Old Aug 9, 2007 | 09:03 PM
  #240
it should, but i need to do some more re search. no using filters makes me scared, but majority of the particals that enter the motor will just burn up anyway. they say with itb's you need to change your oil more often than once every 3k.
