NA: ITB's
Originally Posted by MINES13,May 10 2007, 11:22 AM
I lost about 20hp with foam filters. Back to back dyno pull. WildcardTD reported 30hp I think. Bottom line, ITBs and filters don't get along.
well tuning went really good, did around 20 pulls on the dyno.... motor got beat up haha. first time we started with stock 1052 map, idles like a v-twin
, my tuner started sync'ing the butterflies and they were a little out of sync.... then he started tuning away. first pull was 204/142 (stock everything else, just exhaust... no headers either
). down the line, my fuel return line leaked... i guess you never know until it really gets hot.... changed the hose and started tuning again. 2.5 hours later, he pulled a 210/146 (196/136 from my previous run with exhaust only) we stopped and called it a day... did couple test drive and all i can say is WOW!!! throttle response is definitely the most noticeable change, hp gain well 14hp not bad. we cant really do a realtime street tuning with real road load coz i dont have built in wideband yet..we will do that soon, so we can get street tuned compare to dyno.
cold start is ok, step on the gas for a little bit and crank for 3 seconds and it starts fiine, idles at 900rpm... sounds and feels like stock! after tuning on saturday i drove it 150 miles with no problem and yeah drove it all day yesterday... just cant get enough of it
yeah those magnetti injectors are awesome for its little form factor compared to RC and it's subtle. i havent really get a chance to look at my logs again and see data after couple days of driving. but i know duty cycle on those injectors are really low.
props to casey at MODACAR for the badass tuning and the guys at modacar for all the help!! also to jimmy@fuji-racing for all his technical advice during my install process... im a happy camper!
). down the line, my fuel return line leaked... i guess you never know until it really gets hot.... changed the hose and started tuning again. 2.5 hours later, he pulled a 210/146 (196/136 from my previous run with exhaust only) we stopped and called it a day... did couple test drive and all i can say is WOW!!! throttle response is definitely the most noticeable change, hp gain well 14hp not bad. we cant really do a realtime street tuning with real road load coz i dont have built in wideband yet..we will do that soon, so we can get street tuned compare to dyno.cold start is ok, step on the gas for a little bit and crank for 3 seconds and it starts fiine, idles at 900rpm... sounds and feels like stock! after tuning on saturday i drove it 150 miles with no problem and yeah drove it all day yesterday... just cant get enough of it
Originally Posted by lawerence,May 5 2007, 09:27 AM
So are you running this car and setup as your daily driver?
I would LOVE to pick up midrange like that, I can not imagine how much of a difference it would make.
Where in FL did you get your car tuned?
I'm in sarasota and have had my RX7 tuned (full aem EMS) locally, but when I took the S2K to him and started talking about it he pretty much told me I should find someone who specializes in them.
Originally Posted by alejo,May 6 2007, 10:19 AM
what itb system do you have?
48mm throttle $2875.00 USD
50mm throttle $2975.00 USD
50mm throttle dual injector/port $3875.00 USD
...but I got mine from ebay for half that cost
Originally Posted by 240sxer,May 7 2007, 05:46 AM
someone mentioned that you need to mod the itbs in order to keep ac/heater, anyone here running the itbs and still been able to keep climate?
I have full climate control, and I didn't have to mess with anything except my idle fuel and timing pills to keep the engine from bogging too bad when the A/C compressor kicks on at idle.
Originally Posted by APEXSEAL,May 8 2007, 08:09 PM
Originally Posted by lawerence,May 9 2007, 11:36 AM
Are any of you guys running ITBs actually using the car as a daily driver?
My S is the weekend warrior for now, but it is SO much more fun to drive than my DD subaru LGT that I am contemplating selling the suby and driving the S everyday.
Problem is that I seem to modify cars beyond the DD point
I have an RX7 that used to my DD until I got crazy with it.
So does anyone actually DD with ITBs?
hey nate, so you been daily driving that monster with no filters or screens whatsoever in the engine bay to prevent alien stuff (i.e cats, birds) from going in? how about when autoxing? youre not scared of sucking gravels? or maybe cones? HAHA
im thinking of putting a metal screen sandwiched between the horns and tb just to prevent big rocks from going in... or cover every holes in the eingine bay with screen.
