ZEAL Function B6
Old Sep 16, 2008 | 08:04 PM
VeilSide AP1's Avatar
Unhappy ZEAL Function B6
Please someone chime in, im having issues with this suspension im getting a weird noise from the rears as if the top bolts were loose but everything is on tight, PLEASE HELP!
Old Sep 17, 2008 | 04:50 PM
ttt
Old Sep 17, 2008 | 07:52 PM
type59's Avatar
too much preload? Bottoming out?
Old Sep 18, 2008 | 06:00 AM
I think i figured it out, i will take it apart today and see if i am correct, Thanks!
Old Sep 21, 2008 | 07:58 PM
lordbyron's Avatar
update?
Old Sep 24, 2008 | 07:06 PM
AP2 David's Avatar
Originally Posted by lordbyron,Sep 21 2008, 07:58 PM
update?
x2
Old Sep 26, 2008 | 10:03 AM
breakneckS2k's Avatar
in for an update.
Old Oct 29, 2008 | 10:28 PM
RuRoUni_SS's Avatar
if this is the same as what happened to mine, a rebuild isn't that expensive. $100 per corner. if its the shafts, $90 per shaft.
Old Nov 7, 2008 | 12:26 PM
Mr. Francesco's Avatar
what is the results?
Old Nov 7, 2008 | 08:29 PM
circuitclub's Avatar
Active Streak: 30 Days
if its on pillowball mounts, im guessing the damper body is not bolted onto the top hat tight enough. many ppl are afraid of over tightening which they should be cause it can ruin the damper, but if there is play, it will clunk under suspension travel
ChrisPackit
Mar 1, 2019 03:33 AM
jdblood202
Oct 24, 2013 07:42 AM
Funat9
Jul 1, 2008 05:08 AM
ryu_2k3
Oct 24, 2006 01:59 PM
cdelena
May 2, 2001 03:30 PM
