Help.. Suspension noise
Old May 1, 2001 | 04:45 AM
cdelena's Avatar
I have a suspension noise, a
Old May 1, 2001 | 04:58 AM
funcar's Avatar
The shock sounds logical to me.
I had a big off at Hallet in my 944 and after that I too got a sharp clunking sound under similar conditions. I knew it was the shock. You can take the shocks off and take them to a raceshop with a shock dyno and have them checked out.
Or, this is your excuse to buy new coilovers.
Old May 2, 2001 | 03:57 AM
viscreal2000's Avatar
Banned
Hi chris,
The suspension saga continues I see! (: I'm sure this will be little help but you did torque and tighten the top two nuts after you lowered the car right? I had a clunking for a while too, until I realized that I had tightened my shocks before lowering the car to the ground and loading pressure. Just a thought.
-m
Old May 2, 2001 | 06:33 AM
Sideways's Avatar
I found the suspension noise I had definately came from the right side of the car and was actually in the left suspension.. Look for noise transfer. Dealers have a little device that hooks up sensors to various underpinnings and they can hear the noise and find it using the device. Good luck..
Old May 2, 2001 | 03:30 PM
cdelena's Avatar
Thanks for the observations. Actually my new shocks are not yet installed so this happened to the stock setup. You guys are right, I cannot tell where the sound is coming from.
After talking with a few people I have concluded that I may have damaged one of the shocks in my off course excursion so it now clunks when hot and worked hard. I cannot see any damage except for a scar on the inside of the wheel, but it may be more obvious when I pull them off.
The new shocks are custom Koni two-way adjustables machined to allow the placement of the stock spring perches using Koni clips so that I can lower the car and use the stock springs. This is a bit of an experiment to see if I can lower the CG a bit, retain a decent ride, and add dampening on track days.
jyeung528
Sep 17, 2008 03:56 PM
Mike9000
Sep 23, 2007 11:31 PM
mao_titi
Aug 4, 2007 07:43 PM
ryu_2k3
Oct 24, 2006 01:59 PM
mumbler
Jul 5, 2006 11:36 PM
