Installed Tech 2 Front Mount
Old May 26, 2005 | 09:52 AM
  #21
SIIK2NR's Avatar
I say it's 10lbs with fluid....
Old May 26, 2005 | 09:57 AM
  #22
Silver S2k4's Avatar
yeah that sounds about right. It barely weighs 5 pounds but requires a little more coolant to fit the unit and lines.
Old May 26, 2005 | 09:58 AM
  #23
FF2Skip's Avatar
Check.
Old Aug 18, 2005 | 07:09 PM
  #24
MBurnz's Avatar
for anyone considering buying this product, it actually shouldn't be that hard to install (fabricating brackets and such), UNLESS they changed something in '04. i have an ap1 and there was no hardware that came with the core. but there are 2 flanges welded on the side of the core that already had predrilled holes, and they lined up perfectly w/ holes already existing in the car's frame. so it basically took me under 5 minutes to get this thing mounted (that's of course not counting r&r time for the front bumper). and yes, you do have to purchase a longer coolant hose for it to reach. as far as performance, i honestly doubt it will add any power, but definitely add to the "bling" factor. if someone is still running the stock aftercooler radiator, get a temp reading of the tubing right before the throttle body. once i get a chance, i'll do the same and compare if there's a temp difference at all. if anyone is interested, i can take pix if it'll help..
Old Aug 18, 2005 | 08:49 PM
  #25
white_S2000@16's Avatar
nick, ummmm ..............hasnt this been on your car for a while???? looks dope though!!! your car is so dman low though, you know you took a chunk out of my garge floor
Old Aug 18, 2005 | 09:16 PM
  #26
Yeah dude, had to plug the hole in my tire.
Yeah I did put this on a while ago but somewhat needed the thread for instructions so it came alive.
As for the mounting statement, you don't have to drill holes to mount it but I wanted the radiator touching the front bumper and the holes that were drilled were a little further back than I wanted. You also MUST secure the bottom mount or else the unit will tilt, but it does look pretty cool.
Old Aug 19, 2005 | 07:49 AM
  #27
Ro_Ja Boy's Avatar
I actually like the tilt look like on Drew's car. I will consider making a braket for the bottom. So you do need extra coolant hose, huh? Can get that at Home Depot or such?! Thanks Nick!
Ryan
Old Aug 19, 2005 | 09:50 AM
  #28
yeah i got mine at home depot. Make sure you buy a connector too so you can link it to the original pipe. Also get clamps to tighten them down on the radiator.
Old Aug 19, 2005 | 10:13 AM
  #29
Ro_Ja Boy's Avatar
Thanks. Will do. Im decidin whether to make a bracket or not. I suppose I will see when I do the install. Thanks!
Ryan
Old Aug 19, 2005 | 10:16 AM
  #30
You can even use the stock one from the little radiator that came with the kit, just gotta bend it a little.
GDM S2K
Mar 7, 2006 02:34 PM
Luder94
Feb 4, 2006 01:35 PM
spoon us
Jun 12, 2005 09:26 PM
spoon us
37
Jun 9, 2005 09:06 PM
SIIK2NR
May 28, 2005 07:44 AM
