MidWest S2000 Club Kansas, Nebraska, the Dakotas, Missouri, Iowa, and Minnesota
Header advice
Old Mar 11, 2010 | 08:30 AM
tragicfate's Avatar
Default Header advice
so ya i got my asm header in and well it seems to not wanna go on. i tried taking off the engine mount but its still getting stuck any advice or suggestions?
Old Mar 11, 2010 | 09:15 AM
Gamble's Avatar
I had a hard time even getting my stock header back on. It took me like 30 minutes to get it started. The only advice I have is hook it to the head before you hook it to the exhaust.
Old Mar 11, 2010 | 12:11 PM
mpetus's Avatar
Its tricky. It has to be at just the right angle which can be difficult to find. I was about to give up when mine miraculously went ight into place. Hang in there...it'll go.
Old Mar 11, 2010 | 10:10 PM
g352s2k's Avatar
yep what mpetus said. Jack the car up and it should slide right out or up, you just need to do it at the right angle.
Old Mar 12, 2010 | 08:42 AM
D1sclaimer's Avatar
If its anything like my header install, I had to take off the motor mount and use the scissor jack between the engine and chassis so I could fit my header in.
The stock header should easily go in and out at the right angle, but many aftermarket ones dont.
Old Mar 12, 2010 | 12:13 PM
tragicfate's Avatar
yep i finally got it on useing the jack to push the engine over i was pumped but now i for got how the motor mount goes back in im sure ill figure it out but right now i just needed a samll break to just sit back and look at the sexyness in my engine bay. thanks for the help guys
Old Mar 12, 2010 | 01:26 PM
D1sclaimer's Avatar
I demand pics!!!
Old Mar 12, 2010 | 02:29 PM
tragicfate's Avatar
yep now its all on asm header invidia 70mm tp and invidia 70mm N1 dual its sex... ill post pics later like after it stops rainin and i have a chance to clean the ride up.
Old Mar 12, 2010 | 02:52 PM
dsddcd's Avatar
Oh boy, it you think that is hard what are you going to say when you go turbo?????
Old Mar 12, 2010 | 03:11 PM
D1sclaimer's Avatar
I don't know if I'd call it hard, just an inconvenience. s2kmike helped me out and he can vouch that it needed some force to be pushed to fit the header in.
EDIT: Now that I look back, I think you may have been talking to someone else.
skibum
Jul 2, 2009 06:23 AM
rickw06
Jan 10, 2009 03:44 PM
HNC
Aug 12, 2007 01:05 AM
alejo
Jul 31, 2007 06:14 PM
Fongu
May 9, 2005 06:28 PM
