lude problems?
Originally Posted by Bass,Jan 8 2007, 02:21 PM
no biggie these things happen on the phone with AAA getting a new membership so they can tow the lude home
the alt is an easy fix
Good Luck Steve, sounds like you have it narrowed down already. Yeah I learned my lessons on powerwashing the engine bay. I always cover the dist. and the alt. when washing the engine bay. And never with a pw again
Originally Posted by MikeyC,Jan 9 2007, 09:16 AM
I've washed many different engine bays over the years. I never ever would use a power washer. I just use my garden hose and set it to a medium pressure spray. Then I just keep it moving so as not to soak one spot. Some engines seem to be more sensitive to water than others. Although I've never washed one, I understand the Corvette engine to be extremely water sensitive. There's something called opti-spark or something like that on the engine and if it gets wet . . . poof! You'll be out several hundred dollars to fix it.
Originally Posted by Bass,Jan 9 2007, 11:06 AM
nope no towing on the 'lude as she just carries basic insurance (well now i have aaa so i should be all set)
old alt is out just waiting for the new one to show up
Originally Posted by PokS2k,Jan 9 2007, 10:01 AM
I too have only used a garden hose. If it is a really dirty engine then I'll spray with a citrus based cleaner, let it soak for 10 minutes and then carefully spray it off. I try to stay away from electrical boxes, the alternator and other exposed parts which are lubed (citrus cleaner might disolve the lubricant).
especially if you have some bling under the hood
