Excel Help
Old May 14, 2009 | 10:14 AM
mingster's Avatar
Default Excel Help
say i've got 2 columns, 1 column is name, and the other is a set of numbers associated with the name.
now, i make a list in Excel (different column) using Data Validation tool (that's what pressing F1 told me), but how do I get it to populate the cell below this column automatically with the number associated with that name?
For example:
ABC | 123
XYZ | 234
NBC | 456
so i have a drop down box that's got ABC, XYZ, and NBC in another column. how do i get 123 automatically filled into the box below when i select ABC from the drop down box?
thank you for your help.
Old May 14, 2009 | 10:16 AM
S2k_MoZo's Avatar
The only way I know is to write a macro?
Old May 14, 2009 | 10:30 AM
DFWs2k's Avatar
you make an if statement , =if(targetcell="ABC","123",if(targetcell="DEF","45 6",if(targetcell='GHI','789',"N/A")))
didn't use your exact things cuz i didn't feel like scrolling back up
Old May 14, 2009 | 10:31 AM
DFWs2k's Avatar
you put that formula at the cell to the right of your first abc/def/ghi, and then click in the bottom right of the cell with the formula and drag, or double click in the bottom right of the cell with the formula
Old May 14, 2009 | 10:43 AM
trainwreck's Avatar
what about =vlookup(a1,a1:b3, 2, true) in the column? if you use vlookup make sure you stratify column 2. if you are vlookup up text, also, use the trim( ) command to get rid of any spaces in the cell and dont forget quotes.
=vlookup(trim(a1),a1:b3, 2, true)
Old May 14, 2009 | 10:46 AM
DFWs2k's Avatar
vlookup is too complicated for this situation, and he didn't say that he wants to have a key somewhere else on the sheet
Old May 14, 2009 | 10:54 AM
trainwreck's Avatar
i am assuming his list is more than 3 items long. if just 3 rows long, op can get away with if statements. but, if more data, vlookup is the only way to go, unless he loves writing if statements.
maybe i misunderstood the question.
if you just wanna be able to click on something in column 1 from a dropdown menu and have the associated column 2 data, its even simpler than if statements.
just go to DATA->filter->auto filter.
Old May 14, 2009 | 11:00 AM
thebig33tuna's Avatar
sounds like a vlookup situation to me.
Old May 14, 2009 | 11:11 AM
DFWs2k's Avatar
oh gotcha, i assumed if it was a large list (greater than 5) he would've specified, i agree with you now
Old May 14, 2009 | 03:02 PM
mingster's Avatar
oh thank you all for the great input!
how can i forget vlookup?!! going to try that tomorrow
thanks again everyone.
the list is actually 8 variables long, each with a fixed value.
ilvmys2000
Jul 7, 2009 11:09 AM
JasonX82
Oct 28, 2005 07:37 AM
wantone
Sep 17, 2004 12:44 PM
bridow
Apr 24, 2004 05:51 AM
