Excel Help
say i've got 2 columns, 1 column is name, and the other is a set of numbers associated with the name.
now, i make a list in Excel (different column) using Data Validation tool (that's what pressing F1 told me), but how do I get it to populate the cell below this column automatically with the number associated with that name?
For example:
ABC | 123
XYZ | 234
NBC | 456
so i have a drop down box that's got ABC, XYZ, and NBC in another column. how do i get 123 automatically filled into the box below when i select ABC from the drop down box?
thank you for your help.
For example:
ABC | 123
XYZ | 234
NBC | 456
you put that formula at the cell to the right of your first abc/def/ghi, and then click in the bottom right of the cell with the formula and drag, or double click in the bottom right of the cell with the formula
what about =vlookup(a1,a1:b3, 2, true) in the column? if you use vlookup make sure you stratify column 2. if you are vlookup up text, also, use the trim( ) command to get rid of any spaces in the cell and dont forget quotes.
=vlookup(trim(a1),a1:b3, 2, true)
i am assuming his list is more than 3 items long. if just 3 rows long, op can get away with if statements. but, if more data, vlookup is the only way to go, unless he loves writing if statements.
maybe i misunderstood the question.
if you just wanna be able to click on something in column 1 from a dropdown menu and have the associated column 2 data, its even simpler than if statements.
just go to DATA->filter->auto filter.
oh thank you all for the great input!
how can i forget vlookup?!! going to try that tomorrow
thanks again everyone.
the list is actually 8 variables long, each with a fixed value.
