I need help with AIM.
Old Jan 29, 2002 | 11:37 AM
John David's Avatar
Default I need help with AIM.
I use trillian; however, my connection to AIM has failed recently. When I click on the connection manager under the AIM contact to try to establish a connection, it says that, " a connection with this name already exist. If you wish to reconnect, please right click the existing console window and do so."
When I go to the toggle status window, this is what it says:
Start of Console buffer: Tue Jan 29 14:26:47 2002
*** Creating connection "JohnDavidS2000"
*** Buddy rights: 200 buddies allowed, 750 watchers allowed.
*** You have been marked as away.
*** BOS rights: 200 max on permit list, 200 max on deny list.
*** You have successfully connected to the AOL Instant Messenger service.
*** Fatal error (couldn't receive flap): Error Code 10054
*** Disconnecting.
*** Reconnecting to AIM as "JohnDavidS2000".
*** Will attempt 10 connections with 60 second intervals.
*** Connecting to AIM as "JohnDavidS2000", attempt #1.
*** Disconnecting.
*** Disconnecting.
*** Error logging into AIM: You are attempting to sign on again too soon.
*** See http://www.aol.com for more information.
*** Disconnected.
End of Console buffer: Tue Jan 29 14:26:47 2002
Is AIM down nation wide... or is it just me. Anybody out there know what I'm doing wrong?
It has been several days since I have used aim, so I don't know when this error first occurred.
Thanks for your help.
Old Jan 29, 2002 | 11:41 AM
Shamu's Avatar
I sometimes get that error msg. after the connection is unexpected dropped. I just close and re-open Trillian and the connection is fine...
Old Jan 29, 2002 | 11:51 AM
John David's Avatar
thanks for the quick response, but I have closed and reopened Trillian already. When I open trillian back up I still can not connect. I have tried opening AOL im alone without Trillian, and it doesn't work either.
Old Jan 29, 2002 | 12:23 PM
magician's Avatar
Trouble with AIM?
Just squeeze some out of the tube onto the fuzzy end of the toothbrush and use the brush to smear it on your teeth.
Old Jan 29, 2002 | 12:30 PM
Gregg's Avatar
There is a problem w/ Trillian Secure Messaging and AIM
According to the Trillian website you need to disable SecureIM.
  • Go to Preferences->AIM->Misc
  • Deselect "Activate SecureIM Capabilities"
The Trillian team is trying to get it reactivated and believes it still works correctly w/ ICQ.
Old Jan 29, 2002 | 12:42 PM
John David's Avatar
Thanks Gregg I was going to address this post directly to the S2K Days Ass Man... as I knew you would have the answer since you work with this kind of stuff.
Old Jan 29, 2002 | 05:49 PM
Gregg's Avatar
BTW--Cerulean has just released Trillian 0.72. SecureIM is disabled until further notice, but the new client has auto-updating.
You can find it at http://www.trillian.cc
Old Jan 29, 2002 | 06:13 PM
josh3io's Avatar
if you have a software problem, it's always a good idea to check the site that you got it from for updates.
The Raptor
Oct 30, 2007 12:07 PM
stockae92
Aug 1, 2005 11:14 PM
simioen
Jun 4, 2003 02:51 PM
