squeeky sounds
Old Nov 28, 2001 | 05:19 PM
MugenS2000's Avatar
Default squeeky sounds
hey i need some help, i have an acura cl 3.2 2001 model and for some reason now it makes a squeeky sound when i sit down and move around in the car i think tis coming fron the front left side. Please help! Itsounds like a rubber ducky.
Old Nov 28, 2001 | 06:03 PM
s2k_scott's Avatar
MugenS2000,
My wife's 2000 TL had sort of the same problem. It was coming from the seat belt latch fastner bolt. I found it by taking the seat belt off and the squeaking would stop. I took it to the dealer that actually had a memo on this.
My refrence to the seat belt latch is refrencing the piece between the seat and the console. It seems to be fastned with a bolt that may need to be tightned a bit.
Hope this helps!
Old Nov 28, 2001 | 06:21 PM
MugenS2000's Avatar
Well, i checked but the sound is coming from the tire/wheel area. I told my sister to get into the drivers seat and she moved around and thats where the sound was coming from. Hope this helps.
Old Nov 28, 2001 | 07:16 PM
tokyo_james's Avatar
Could it be the shock absorber?
Trying pushing down on the top of the wheel arch and see if that gives you the same sound.....
Old Nov 28, 2001 | 10:46 PM
AnDy_PaNdY's Avatar
Nesting mice
Old Nov 29, 2001 | 02:04 PM
MugenS2000's Avatar
yeah it does..i pushes right above it and it makes the same sounds..does this mean i have to replace the shock absorber or what?
Old Nov 29, 2001 | 02:50 PM
The Raptor's Avatar
Active Streak: 30 Days
Sounds like uncontrollable farting. Better cut back on the beans for awhile.
Old Nov 29, 2001 | 05:19 PM
I would say it is either the shocks or the springs.
If you push down quite hard and then release quickly the car should come back up and stop. If it "bounces" a bit, then it sounds like the shocks need replacing.
watchyosix
Jun 28, 2004 02:37 AM
DodgerFan
Apr 4, 2002 10:26 AM
NJTom2000
Jan 8, 2002 04:18 PM
VTEXTC
Nov 30, 2001 03:52 PM
GMetal
Nov 6, 2001 05:45 AM
